First post, by byte_76
I have an AMD K6-2 550Mhz on a Chaintech 5AGM2. (Sticker on the BIOS chip indicates V5.0)
I would like to overclock the CPU to 600Mhz but when I set the multiplier to 2X it fails to POST.
I have the latest BIOS from TheRetroWeb which is dated 11/02/1999.
Is it possible to achieve 600Mhz, or am I out of luck with this board and CPU combo?
Reply 1 of 6, by kixs
Non plus cpus are pretty much already at their max. So usually even small overclock is not possible. Even some plus versions have trouble working at 600Mhz.
Visit my AmiBay items for sale (updated: 2026-03-23). I also take requests 😉
Reply 2 of 6, by Thandor
The K6-2 550 is indeed already at the max. Perhaps you could dive into optimising BIOS settings and improve RAM latency settings. The difference between poor and optimal RAM settings might be, in some cases, bigger than 50MHz extra CPU clock 😀.
thandor.net - hardware
And the rest of us would be carousing the aisles, stuffing baloney.
Reply 3 of 6, by cyclone3d
Are you all smoking something? Have you actually ever tried overclocking a regular K6-2 on a good board?
Back in the day, when I had a K6-2 550 on an ASUS P5a as my main \ only machine, I had it over clocked to 660Mhz (120*5.5) on air.
Saying the 550 and even lower regular K6-2 CPUs are at their max is silly.
Yamaha XG repository
YMF7x4 Guide
Aopen AW744L II SB-LINK
Reply 4 of 6, by BitWrangler
CXT CPUs commonly have another 50mhz in at least, the sticking point for pre-CXT was around 366-400, so if you had a pre-CXT 350, you may have been "at max" practically. There were meant to be some highly cherry picked 400s, but few and far between, very small yield.
So anyway, check 2x works on a lower FSB, check RAM/Cache timings backed off, check revision oddities of chipset (Early ALI Super 7 had some sticking point I think) Check you are getting voltage at CPU you're supposed to, if it's only getting 2.1 V or something it will hold it back. Also you might be getting volt droop at a higher clock, so maybe giving it 2.5 will help.
Reply 5 of 6, by nickles rust
I ran a 500AFX at 570MHz for years, I think at 2.4v. I've seen 550AGR at 600MHz, at 2.5v iirc. I think some of the 533AFX will hit 600MHz. You can try and see what you get. Watch the temperatures on the CPU and VRM components.
If you search on this forum, there are probably lots of posts about overclocking the various K6 chips. If 600 is your goal, the "plus" chips are probably the easiest route. Good luck!
Reply 6 of 6, by Repo Man11
The K6-2 533 I had was possibly the worst overclocking CPU I've ever had. IIRC it was the 2.4 volt model and I had to boost the voltage to get 550 MHz out of it. The lower the core voltage the CPU is rated for, the better your luck will generally be for overclocking it.
