what front end?
First post, by dbarton
I've been using DOG and I like it, but it doesn't seem to support .72.
Anyone know if that's changing?
{I wrote to author and got no response.}
If not, what the new standard front end I need to change to?
thanks
Reply 1 of 11, by wd
Rank DOSBox Author
DOSBox Author
What doesn't work? Think it supports 0.72 just fine, but never used it myself.
Reply 2 of 11, by dbarton
Some of the syntax it writes is no longer valid.
such as:
"cycles=fixed 5000"
is the new way to write this
Reply 3 of 11, by wd
Rank DOSBox Author
DOSBox Author
0.72 does not use the new syntax.
Reply 4 of 11, by dbarton
Must just be the test version I have here then..
Reply 5 of 11, by wd
Rank DOSBox Author
DOSBox Author
Download the official dosbox 0.72 release from dosbox.com
Reply 6 of 11, by Qbix
Rank DOSBox Author
DOSBox Author
i think DBGL supports the CVS syntax
Water flows down the stream
Reply 7 of 11, by dbarton
I'm using a test build, so maybe will just wait till it's all caught up...
So this new syntax isn't in normal .72, but sounds like will be in next release, yes?
I hope D.O.G. gets updated. I'm perfectly happy with that one.
Reply 8 of 11, by rcblanke
That's correct; cputype, cycles, machine setting etc. are all supported for DOSBox CVS in the latest DBGL release.
Reply 9 of 11, by dbarton
Does this new terminology in the CVS mean it will be standard in the next release?
Reply 10 of 11, by wd
Rank DOSBox Author
DOSBox Author
It might, or it might not.
Reply 11 of 11, by Qbix
Rank DOSBox Author
DOSBox Author
The CVS is a work in progress, hence we can't say whether it stays this way or not.
