Reply 22 of 50, by the3dfxdude
If you are thinking of an old kernel for running on a 386, I checked my current glibc 2.33, and the minimum kernel requirement is 3.2, which still supported the 386. gcc still supports the 386 today (hopefully they don't break it accidentally again). So based around that, if you carefully select what you really want to run, you could probably have a fairly recent linux software environment (who cares about the old kernel, 386 systems haven't changed much) running some useful stuff. (not everything)
But of course, the 386 was never really all that useful for linux due to lack of memory. If you can drop firefox though, you pretty much can run some kind of linux on anything. I'd be happy to lessen my use of firefox and chrome. If you look at the thread where Linus says drop the 486 support, someone responded reminding that they had not so far because 486 class systems were still being sold recently?? It seems linux still is useful on a 486. Somewhere.
For an alternative browser, I really do use lynx. In fact regularly on my eeepc 1000. If you really want graphical, I do like netsurf.
Reply 23 of 50, by foxbat
This is true that some 486 based devices can be still found in the industry as control boards for some kind of machinery. But I do not expect them to get regular OS updates. IMO those boards sit in well protected LAN isolated from any external access and stuck with one kernel version, usually the custom one with which the machine has been bought. Maybe some updates provided by the manufacturer in case of any critical issues with machinery itself, no more. I would expect any modern machinery control boards implemented with some ARM-based SoC which integrates everything in one chip except a coffee machine ;p There are plenty of ARM SoC manufacturers nowadays and Linux kernel support is much better for ARM than it was decade ago.
In context of a graphical web browser I would look for something other than Firefox when it is heavy for RAM and not only that. That is why I asked for any alternatives you know about. The key here is JavaScript support, CSS, SSL etc. And this damn SSEx requirement ... All we need here is to be able to browse 'static' web pages when even i686 based machine will struggle to handle any modern multimedia web page.
Reply 24 of 50, by nickles rust
I'm updating this thread with some of my recent experiences with linux. T2 linux (t2sde.org) seems to be the only current linux distribution that supports old hardware. I was able to install it on my AMD K6-3 machine and most of the usual linuxy stuff works. Compiling packages is tedious, but cross-compiling is expected and works for most things. One of the more recent advances in linux is zram, and this is quite useful on older machines that don't have many GB of RAM to waste. T2 also has the latest kernel and gcc versions, etc.
The attachment T2K6a.jpg is no longer available
The attachment T2K6b.jpg is no longer available
Reply 25 of 50, by DEAT
nickles rust wrote on 2025-08-07, 15:37:
Set up a Gentoo install in KVM/libvirt with a raw image, and dd the image to a physical drive - that's what I did at the end of 2022 to get a distro that works on a 486. They still provide i486 stage3 ISOs and you can change the CHOST to make it an i586 build, which will at least give you a relatively recent version of wine that will run. This site is good advice for making a compact kernel, and with some sensible configuration you can get a bootable terminal with 24MB of RAM.
Shame that i486 support is being dropped after 6.15. That said, ISA video card support was dropped from Xorg at around 2008.
EDIT: found the spreadsheet I did back at the end of 2022, testing video cards and sound cards.
https://docs.google.com/spreadsheets/d/1epsE- … RtEtKvM9MqRTD4/
One video card not listed there is my PCI Geforce FX 5200, which does work and is even detected by mesa, but whenever I'd try to do any OpenGL tests I'd run out of memory. Sound card support is in a much better state overall for legacy hardware, fortunately.
win16.page | Twitch
Reply 26 of 50, by nickles rust
I've still been running T2. Anyone else?
The attachment Screen.png is no longer available
Reply 27 of 50, by kagura1050
There's a distribution called opencocon (and its derivative, kitsuneko)...
It has a very small memory footprint, which I think makes it ideal for older machines.
Automated builds were running until last September:
https://get.opencocon.org/snapshot/v11-snapsh … glibc/20250919/
古いマシンで新しいOS(Linux/NetBSD)を動かすのが好き。
All or most of the posts are created using Google Translate.
Timezone : UTC+9
Reply 28 of 50, by bocke
kagura1050 wrote on 2026-01-24, 07:59:
There's a distribution called opencocon (and its derivative, kitsuneko)... It has a very small memory footprint, which I think m […]
It's based on Openembedded and it's not a general Linux distro. It's meant to be used as a thin client. It apparently supports several remote desktop protocols, but the site doesn't go in details about it, beside listing them. Neither does it list requirements.
opencocon is smaller-footprint GNU/Linux distribution optimized for Thin-client purpose. It is useful to re-use old computer, be […]
opencocon is smaller-footprint GNU/Linux distribution optimized for Thin-client purpose. It is useful to re-use old computer, because response speed is faster than standalone use.
Unique feature of opencocon:
  • No desktop environment : All desktop environment from host computer
  • No user save-able area
  • Support some 90′ PCs (Windows 9x generation), and In particular, support the mania favorite PCs (Toshiba Libretto, Sony PCG-C1, …)
  • Supports some Thin-client Protocols: XDMCP, RDP, VNC, SPICE, X2go
So, not a general purpose distro - meant for remote desktop access.
Reply 29 of 50, by bocke
Kitsuneko actually looks useful for general use. But it doesn't come with desktop. It replaces it with FBTerm - a high res terminal emulator implemented on top of framebuffer. Fbterm, I think, also supports international characters and unicode and with an input method, it should work fine for complex script languages like Japanese/Chinese. As far as I remember from my earlier reading on Fbterm, it should support multiple input models (I am a long time Linux reader, but check everything I put "I think" or "as far as I remember" in front. Talking out of memory.)..
Only thing "bad" about Fbterm is that I am not sure if there is an actively maintained fork, nowadays.
More info:
https://gitlab.com/opencocon/meta-kitsuneko
Reply 30 of 50, by doshea
nickles rust wrote on 2026-01-24, 02:21:
How does Firefox perform on that system? I recall about 20 years ago I was running Firefox 2.0 under Windows 98 SE on a Pentium 166 with 128MB of RAM and it took an entire minute just to start, although I think it wasn't so bad after that. Your system is quite a bit more powerful than that one, but Firefox and the web have gotten heavier in the last 20 years!
Reply 31 of 50, by nickles rust
It is slow but I really like the fact that it does still work. Memory is the main problem. I have 512MB and you can see that firefox with only a few tabs on simple forum sites is already at around 700. Using zram helps a lot because all the bloat and sloppy programming will at least compress well. Swapping to disk instead would probably basically deadlock the system. Firefox will also let you block or turn off a lot of modern web garbage.
Reply 32 of 50, by kagura1050
bocke wrote on 2026-01-24, 09:56:
Well, actually, opencocon isn't practical...it's purely experimental.
Also, I'll report to the project members that the required machine specs aren't listed on the website.
As a rule of thumb, if you're "installing" it directly to the HDD using dd, a 486DX with 20MB of memory should barely run it, and a Pentium with 32MB of memory should work fine (I saw opencocon running on a Libretto 50CT last week at OSC Osaka 2026)
bocke wrote on 2026-01-24, 10:04:
At least in the snapshot build, kitsuneko should have started up X11 and displayed an xterm.
I'd rather go for kitsuneko than opencocon (since I have a nearly blank i486 Linux environment including a compiler, all I need to do is set up the environment the way I want to).
FYI: If I remember correctly, opencocon/kitsuneko uses NetSurf as its web browser software.
Timezone : UTC+9
Reply 33 of 50, by nickles rust
T2 now has Firefox 155 with javascript jit for 32bit. I have not tried it though. I can't get the newer installers to work, and it would probably take a week to compile. But there is still hope!
Reply 34 of 50, by Kahenraz
nickles rust wrote on 2026-02-05, 15:02:
My workaround is to run web browser remotely over X forwarding. That way I can still browse the web without being limited by the processor or memory. Web browsing is the one thing that doesn't age well with retro computing.
Reply 35 of 50, by bocke
kagura1050 wrote on 2026-02-06, 00:01:
It's quite possible. I was trying to get more information from the source repos instead trying to run it, so I might've missed something . If that's true, I apologize for disinformation. 😀
Reply 36 of 50, by bocke
Anyway, about other suggestions:
I've been following René on Instagram and he has quite a few retro programming projects, so I would guess T2 should be pretty retro friendly.
Slackware 14.2 should be mostly i586 friendly. Most packages are i586 or i486. Very few are i686. One of them is SMP kernel which you would avoid anyway on Pentium I. Non SMP kernel is i586.
Depending on the purpose of the system, 128-256 MB can be enough for minimal WM. 512 MB will work ok with Xfce given you don't run memory hogs such as Firefox/Thunderbird/Chrome/LibreOffice. If you run those, 2 GB would be minimum.
Those are of course approximate numbers and limited to 32-bit release.
Case in point, ASUS EEE PC 701 with 2GB of ram on SLackware 14.2 (2018).
The attachment Screenshot_2018-10-08_18-11-59.png is no longer available
Reply 37 of 50, by zapbuzz
Doesn't matter what processor, OS or web browser if it doesn't support SSE2 instructions there is no modern web support possible because nobody knows SSE they just copy each others SSE2 code. Think of all the old machines online if someone wrote SSE code. Then there’s older CPU's without SSE good luck with that!
IRC still works but with secure sockets on the rise soon there will be nothing there too.
Old browser compatible web sites are almost non existent because of the abuse.
Reply 38 of 50, by nickles rust
zapbuzz wrote on 2026-09-08, 06:19:
Doesn't matter what processor, OS or web browser if it doesn't support SSE2...
I have a K6 running a recent linux version with Firefox 136, as shown above. The latest builds of T2 have many of the usual linux updates, as well as Firefox 155 with a javascript jit for 486 as well as PowerPC. T2 does run on a 486, but RAM is probably the biggest limitation for a GUI, or a browser. 128MB is probably the minimum for an install, unless you're an expert and can manually tweak settings. I'd say 256MB is probably the minimum to load modern Firefox, and maybe 512MB to actually run a few web sites.
T2 is one of the most up-to-date linux versions, AND they still work to support diverse hardware. They have undeleted a lot of stuff and are even trying to improve drivers for things like old graphics cards. To me, the main point of linux is that it runs on anything, and T2 seems to be the only version that still has this philosophy.
Reply 39 of 50, by Jo22
Another problem with SSE2 is OS support, things like context-switching (XMM registers).
Windows 98SE, for example, was released when x87, MMX, 3DNow! and SSE were known.
SSE2 support is not natively available to such OSes.
Applications would need to take care of it themselves.
Hm, maybe an SSE2 emulation could be integrated at kernel level?
Unofficial Mac OS X distros had SSEx emulators for compatibility reasons.
