Empire Earth III
First post, by LuisMenethil
Hi. Coming back here after so many years. Nostalgic.
Guys, I'm trying to play Empire Earth III, GOG version. Is there any way to make the game more stable, or is it a lost cause? I'm encountering several technical problems.
Can I be honest when I say I'm shocked by the animation of the boats in-game?
Reply 1 of 3, by Solus
Good place to start with would be PCgaming, or just use dgvoodoo2 or you use dxwrapper by elishacloud since the game uses directx9.
Reply 2 of 3, by LuisMenethil
Thanks. What is the difference between dgVoodoo2 and dxwrapper?
Is there a way to tell if the GOG version is using any of these tools?
Reply 3 of 3, by Solus
Sorry for late reply, I'm not tech savvy, as for how to tell if gog versions uses these tools, well dgvoodoo2 has watermark, so you will see that it works, as for dxwrapper, it doesn't have watermark, but generally you will see if it works, with these tools it mostly trial and error with them.
