Finally giulio and TUS released 88emu sources at GitHub today. […]
5 devices are emulated: SC-88 - pure one, VL and PRO versions, SC-8850 and old good SC-55mk2 - judging from remarks, they used Nuked SC-55 sources for it.
SC-8820 isn't supported atm, but once TUS have the hardware, they will fix it for sure.
Also you have to provide your own ROM images for any device to start.
I've built binaries for my system (Linux x64) and tested them for a while.
88emu appears to be a standalone version, publishes 3 new MIDI IN ports to the system (A, B, announcements) so it should be directly compatible with DOSBox and such, didn't test it yet.
Incorporates a built-in MIDI file player for testing , GUI is scalable from 50% to 300%.
Generally all synths are working but we need more testing to detect alpha version peculiarities.
For example, 32 channel midis sound kind of weird but LCD graphic demos look all OK.
More teasing screenshots to follow:
The attachment 88.png is no longer available
The attachment 88VL.png is no longer available
The attachment 88pro.png is no longer available
The attachment 8850.png is no longer available
The attachment 55mk2.png is no longer available
