Reply 40 of 41, by Mike1978
red-ray wrote on 2026-09-09, 15:53:
Strange, it's OK on NT4, maybe it's too new for W95A. What happens with the attached? Do all the missing .DLLs load? […]
Mike1978 wrote on 2026-09-09, 15:24:
The font you shared previously wouldn’t load and was saying corrupted when I tried to add it.
file.php?id=248911
it takes a few minutes to launch as you may imagine it’s working hard.
I wanted to attempt to skip some of the hardware not present.
I doubt doing -NOACPI -NOPCI -NOSMB will make much difference, either way if there is a lockup I would prefer to fix it.
If really needed I would do SIV32L -NOACPI -NOPCI -NOSMB then Menu->File->Save Selected as this would mean the SIV start-up + per section times would be in the save file.
Actually yes I do have a couple of MCA systems but I’m a little time limited to do exhaustive testing.
Looking at your profile I guessed as much. AFAIK SIV has never run on an MCA system, I suspect/hope it does OK.
Ray
Full run - i installed the fonts and they appeared to work - do you need the additional cpu check as well ?
Reply 41 of 41, by red-ray
Mike1978 wrote on Yesterday, 20:05:
Full run - do you need the additional CPU check as well ?
Thank you, most things are now as I would expect, but the CPU type detection, speed and L1 cache size are strange, doing the additional CPU check should tell me why.
red-ray wrote on 2026-08-28, 08:19:
SIV should have reported IBM 486BLX2 and I can't see why it didn't, please do SIV32L -DBGCPU -EXIT=20 > SIV_DBGOUT.log and post the .log file.
The AAM is used to measure the CPU speed and for IBM Blue Lightning it takes 17 rather than 15 cycles, allowing for this 65.1 * 17 / 15 = 73.78 which is still low, please post a screen shot of Menu->Help->Conversions->CPU MHz so I can see what get's reported.
Comparing your system to a Cyrix Cx486DLC @ ~33 MHz it's much slower, I wonder why?
file.php?mode=view&id=248963
On a different IBM 486BLX2 @ 66MHz as below was reported.
file.php?id=248965
Looking at [Cache-0 Latency] the time for 16KB is much the same as for 24KB, are you 100% sure the L1 cache is enabled in CR0 (Control Register 0) ?
SIV32L - Generic 486 DX L1 8KB on \\MIKE - Windows 95A  V4.00  Build 950
Stride Minimum Total
Size 32 64 128 0.25KB 0.5KB 1KB 2KB 4KB Time Time
4KB NA NA NA NA NA NA NA NA 3.562 3.562
6KB NA NA NA NA NA NA NA NA 3.602 3.602
8KB NA NA NA NA NA NA NA NA 3.562 3.562
12KB NA NA NA NA NA NA NA NA 3.559 3.559
16KB NA NA NA NA NA NA NA NA 3.016 3.016
24KB NA NA NA NA NA NA NA NA 3.200 3.200
32KB NA NA NA NA NA NA NA NA 3.318 3.318
48KB NA NA NA NA NA NA NA NA 3.251 3.251
64KB NA NA NA NA NA NA NA NA 3.348 3.348
96KB NA NA NA NA NA NA NA NA 3.461 3.461
128KB NA NA NA NA NA NA NA NA 3.707 3.707
192KB NA NA NA NA NA NA NA NA 4.907 4.907
256KB NA NA NA NA NA NA NA NA 5.342 5.342
384KB NA NA NA NA NA NA NA NA 5.732 5.732
512KB NA NA NA NA NA NA NA NA 5.433 5.433
768KB NA NA NA NA NA NA NA NA 4.985 4.985
Total 16 [_]Minimum [_]Log to C:\siv_v5.88_beta_09\SIV_MIKE.csv Time 63.985
Description Memory
Cache Size 5MB
Delay Cycles NA
Delay Time 4.985 [_]Repeat # 1
