First post, by Zuofu
I have been trying to find a full version or at least levels 1-4 version of Zone 66 that works with Soundblaster audio. I saw that user WonderSlug has posted the shareware version and that works with Soundblaster (not just Adlib) if run in pure DOS w/o even HIMEM.SYS loaded with the /s option. This is the original version that doesn't run at all with HIMEM.SYS and will not run at all in DOS 7 variants (as far as I know). Unfortunately, every other source I've ever found of the full/registered version is of the later version which will run in DOS 7 and will run with a memory manager loaded but doesn't seem to support SB, only GUS and Adlib. I even when as far as purchasing the B&N mission disk for levels 3&4, but even though it extracts from the floppy fine, I can't get it working on any of my period correct systems.
