First post, by Sedrosken
- Member
I've got a build up and running using this board using a fairly pedestrian PMMX 233 and 64 megs of SDRAM, paired with an AWE32, PRO/100B, and Matrox G200 PCI. I know if I felt like it I could push some K6-III type shenanigans, but that's not the goal for this build, at least right now. I'm currently running the J.3 BIOS from feiopa here: mb-8500ttd manual needed primarily for the fixes to disk capacity and UDMA mode being silently toggled off on 9x on UDMA >4 devices.
So far, after working out the bugs, it's been pretty stable but with some weird exceptions. I know feiopa documented that the /sb switch is needed when running Speedsys otherwise it'll lock up when polling DMI -- the problem is, Speedsys isn't the only thing that does this. WMI in Windows 9x can do it, DXDiag can do it... I'm sure there's more stuff that can do it so my question is, is there a way to fix this DMI poll freeze? Is there a version of the BIOS that has the hard drive bugs fixed, and has working DMI, but maybe for instance doesn't support all the different CPU wackiness one can get up to with this board? At least I know WHY it's freezing when it does, but it's still not a great feeling when this can't even run DXDiag...
Shoushi: Dimension 9200, QX6700, 8GB D2-800CL5, K2200, SB0730, 1TB SSD, XP/7
Kara: K7S5A Pro, NX1750, 512MB DDR-286CL2, Ti4200, AU8830, 64GB SD2IDE, 98SE (Kex)
Cragstone: Alaris Cougar, 486BL2-66, 16MB, GD5428, CT2800, 16GB SD2IDE, 95CNOIE
