First post, by majestyk
- Oldbie
This is a sad story so far. I recently bought a FIC PSC-2000 LPX mainboard that is nearly identical to the PSK-2000 version except that the PSC-2000 has no "AT&T" logo on it and has a Cirrus Logic "CL-GD5436" onboard VGA, while the PSK-2000 has a "S3 Trio 64" one. The PSC-2000 also has one more DIP-switch for selecting additional CPU multipliers.
The onboard VGA on my PSC-2000 didn´t work, but with a PCI or ISA VGA adapter in the riser card everything was fine.
The Cirrus logic chip gut boiling hot after a few seconds so I decided I had to replace it. I removed the chip and wanted to test if external VGAs would still operate without the chip when I grabbed a wrong riser card from my box. I have plenty of original FIC and AT&T risers, but in a hurry I picked some different model with the same "EISA" connector.
The system wouldn´t start with this card, I noticed my mistake and put the right one in the slot - system still not starting. 🙁
I thought "well maybe it doesnt start when the VGA chip is missing and BIOS tests the chips at startup". But with a different BIOS (same chipset, no VGA BIOS included) I got the same result. So there _might_be_something_wrong...
Here´s the mainboard:
and some riser cards (the one at the top left is the culprit that caused all the trouble)
Next I did a simple "diode test" on all the ISA pins, but there were no irregular results.
Same testing at the PCI pins showed a "floating" "AD30" line. With the original FIC riser the PCI "AD30" pin was routed to the mainboard correctly without interrupion and it was also connected to the "AD30" pins of the PCI-IDE controller, one of the memory buffer chips, the PCI-ISA bridge chip and the System controller chip. Since all chips are conneted to the "AD30" bus line a floating line means all of the chips´ I/O circuits for this line got blown up.
BUT WHY? Closer inspection revealed that the wrong riser card routes the AD30 pin of the PCI slots to the AD22 pins of the chipset - this shouldn´t cause any damage.
Vice versa it connects the incoming AD30 signal from the mainboard (not to the PCI AD22 pins) but to +12V. Obviously none of the chips survived this abuse.
I intend not to give up, but replace the chips one by one.
red "X" = dead chip:
