HwAoRrDk wrote on Today, 09:55:
Yes, but also no. A fuse has defined characteristics on how much current it will hold, and when and how fast it will break current, typically specified by the manufacturer with an I^2t curve. A zero-ohm resistor has none of that. Hell, manufacturers don't even guarantee they're actually 0Ω - typically such a part will have a resistance tolerance specification, which can be as much as ±10%. Yes, it sounds nonsensical that you can have a 10% deviation from zero, but nothing is ever zero resistance (if it is, congrats, you've created a perfect superconductor and a Nobel prize will surely be arriving at your doorstep any day now 😜).
Yes but also, no, we all know the theory, but I also know the practice.
Unlike what the average Joe thinks, fuses aren't there to protect the device, they are there to protect what's upstream, linees, cables, generators, batteries... from burning, exploding, failing catastrophically. So, usually, they aren't critical (I mean theri specs, not their function).
In that specific case a 600mA~1A fuse would be likely the right choice, but is not like if you used a 2 or 3 Amp fuse your PC would instantly catch fire, in case of a short, they would burn before the circuit's trace just like a 600mA one.
As for the minimal price difference, it's true that cheaping on that doesn't make an huge difference, but if you look the matter as any industry do, anything that cost more money than a different solution is considered wasted money, it's matter of principles rather than quantity from that POV.
That said maybe the project had self restoring fuses rather than normal ones, in that case they spared more consistent money, while providing an inferior product, in that case the behavior is not condonable.
