Am5x86-P75-S @ 200MHz (fully stable@3.6V)
Reply 60 of 61, by red-ray
JAKra85 wrote on Yesterday, 19:17:
Oh well, it was a fun project! 😁
(will not give up, need to find a few Am5x86 CPUs)
Oh dear and good luck with the CPU search. AFAIK over-volting CPUs tends to shorten their life.
I guess I have been lucky as my AMD Am5x86 133ADZ happily runs @ 160 MHz on the standard voltage as does my Intel DX4 SK096 @ 120 MHz.
You can set the save filename to include such as the CPU speed.
file.php?id=249400
Reply 61 of 61, by myne
red-ray wrote on Yesterday, 10:48:
JAKra85 wrote on Yesterday, 10:28:
Can't complete. Getting page fault errors at different steps.
red-ray wrote on 2026-09-17, 17:45:
SIV reports the default of 3.45V, if it's @ 200 MHz do you feel SIV should report 3.60V?
Thank you, it's a shame the system is unstable when running W98 🙁
Memtest?
Might be a bad bit in a region dos doesn't/hasn't used.
I built:
