Reply 2680 of 2696, by zaphod77
have you tried springbeats virtual midi cable?
Reply 2681 of 2696, by Falcosoft
zaphod77 wrote on 2026-09-18, 23:22:
Thanks, I have just tried it.
1. I recommend this driver to no one because of the shady practice of redirecting users to a purchase site where you have to spend 10 minutes to find out how to download this driver really for free...
2. This is the strangest implementation of how 'F5 nn' messages can be ruined. This driver extends the 2nd byte of the original message to be part of a Note Off message. The Note Off status byte is hallucinated from nowhere by this driver...
The attachment springbeats.jpg is no longer available
Website, Youtube
VST Midi Driver Midi Mapper
Reply 2682 of 2696, by zaphod77
the original message type is send directly over the rs232 serial bus. it only works there.
it's very odd that virtual midi ports much with things so much, when they actually need to just pass it through, and let the device handle it.
that said, the source is available, so you can try reading it and figure out where it's going wrong.
https://bitbucket.org/springbeats/sbvmidi/src/master/
Reply 2683 of 2696, by Falcosoft
zaphod77 wrote on Yesterday, 00:23:
the original message type is send directly over the rs232 serial bus. it only works there. […]
1. Yes, but in theory It can work anywhere if the driver do not interfere with the message but simply transfer it the in the same form as it has been delivered by the client. WinMM itself can do this without problems. VST2 and CLAP can also do this.
2. The problem with modified kernel drivers is that they have to be signed some way in order to be usable on modern Windows versions by average users.
Website, Youtube
Reply 2684 of 2696, by zaphod77
Okay, the issue here appears to be windows itself messing with stuff, strangely enough.
check the source yourself. you see that it calls a lot of windows functions that aren't defined in the source, and those seem to be what's messing with the F5, because it's not a standard midi byte.
Reply 2685 of 2696, by Roland User
Thank you ) , I firstly try find bug or error in myself solution , that so why I asked you ) , now when I understand taht problem not in my solution , I known what all maked correctly )
Reply 2686 of 2696, by Falcosoft
zaphod77 wrote on Yesterday, 03:35:
It's very interesting since as I have told you the Windows Midi 1.x stack itself handles these messages perfectly: that is they can be sent by either midiOutShortMsg() or midiOutLongMsg() and can be received by devices or drivers. Otherwise VST MIDI driver could not handle these messages either.
And it seems these kernel mode Midi loopback drivers do not handle (and ruin) these messages the same way. E.g. LoopMidi does not create a fake Note Off event form the 2nd byte but simply discards/rejects it:
The attachment loopmidi.jpg is no longer available
Website, Youtube
Reply 2687 of 2696, by Roland User
And this not all , in WinMM MIDI stack available something else strange... for example , avaialble command all notes off or MIDI panic , but WinMM in typical logic this action whitch zero velocity , this you can see in old MS-DOS games for example Nascar Racing if do run game from DOSBOX-X or in press stop in Windows Media Player , I noticed what sent panic or zero velocity in WMP and psent panic or zero velocity in XMPlay with in_midi.dll version 3.07 , not identicaly )
Reply 2688 of 2696, by zaphod77
I tested by using looping the cable directly for out to in inside of the sendsysex app and get different results.
sbvmidi is using directmusic. and appears to use it to validate the midi message.
https://bitbucket.org/springbeats/sbvmidi/src … m.cpp#lines-319
maybe one of you can figure out how to build a virtual midi cable that doesn't do that?
Reply 2689 of 2696, by Roland User
If you have corrupted sysex via DirectMusic , so this problem can not will solved , I get this problem when trying use XMPlay with plugin in_midi.dll , and when I tryed use DirectMusic , I always was get not correct result , because I write DirectMusic remover :
On Error Resume Next
Option Explicit
Dim objFSO, objShell, file32, file64, bak32, bak64
Set objFSO = CreateObject("Scripting.FileSystemObject")
Set objShell = CreateObject("WScript.Shell")
objShell.Run "cmd /c taskkill /f /im xmplay.exe", 0, True
file32 = "C:\Windows\System32\dmusic.dll"
file64 = "C:\Windows\SysWOW64\dmusic.dll"
bak32 = "C:\Windows\System32\dmusic.dll.bak"
bak64 = "C:\Windows\SysWOW64\dmusic.dll.bak"
If objFSO.FileExists(file32) Then
Call TakeOwnershipAndPermissions(file32)
objFSO.MoveFile file32, bak32
If objFSO.FileExists(bak32) Then objFSO.DeleteFile bak32, True
End If
If objFSO.FileExists(file64) Then
Call TakeOwnershipAndPermissions(file64)
objFSO.MoveFile file64, bak64
If objFSO.FileExists(bak64) Then objFSO.DeleteFile bak64, True
End If
objShell.Run """" & objShell.CurrentDirectory & "\xmplay.exe""", 1, False
On Error GoTo 0
Sub TakeOwnershipAndPermissions(filePath)
Dim objWMIService, colFiles, objFile, wmiPath
Set objWMIService = GetObject("winmgmts:{impersonationLevel=impersonate, (TakeOwnership, Security)}!\\.\root\cimv2")
wmiPath = Replace(filePath, "\", "\\")
Set colFiles = objWMIService.ExecQuery("Select * from CIM_DataFile where Name = '" & wmiPath & "'")
For Each objFile In colFiles
objFile.TakeOwnership()
objShell.Run "icacls """ & filePath & """ /grant *S-1-5-32-544:F", 0, True
Next
On Error GoTo 0
End Sub
this solution will force usage only standard devices without DirectMusic )
and only after this , I start get correct result , maybe you this also help )
Reply 2690 of 2696, by Falcosoft
Roland User wrote on Yesterday, 19:17:
We are not talking about SysEx messages right now. The mentioned problematic 'F5 nn' messages are NOT SysEx messages but common system messages. They are very different.
zaphod77 wrote on Yesterday, 14:20:
I'm thinking about writing a purely user mode installable client loopback driver. But unfortunately I do not have much free time nowadays.
Website, Youtube
Reply 2691 of 2696, by zaphod77
So seems directnuusic messes stuff up? And because spring beats uses it, Thats why it doesn’t work.
Need to see other sources
Reply 2692 of 2696, by zaphod77
Okay none of te other virtual midi cables have source at all. i've locate dthe following 64 bit compatible ones.
1) loopbe1 (lousy feedback det3ection, many false positives) you can pay for a source license (!)
2) midi Yoke NG, from the guy who made savihost. no source
3) loopmidi (free, no source)
4) springbeats virtual midi cable (free, with source)
And for NOT free
5) virtual midi cables, and virtual driverless midi cables. both of these are on the ms store, and NOT FREE. no source either.
6) quite a few other raandom and not free cables on the MS store.
7) loopbe30, which lets you shuty of the feedback detection that makes loopbe1 worthless.
loopbe1, sbvmidi, and loopmidi seem to be kernel level drivers (this device is working properly) . while midiyoke ng and vst midi system driver say they have no drivers in device manager.
Reply 2693 of 2696, by Falcosoft
zaphod77 wrote on Today, 07:37:
Okay none of te other virtual midi cables have source at all. i've locate dthe following 64 bit compatible ones. […]
And for NOT free
It seems if we want a LoopBack driver that does not mess with any Midi messages and also compatible with the Midi 2.0 stack of Win11 then only user mode drivers can work.
https://github.com/microsoft/MIDI/issues/1217 … ment-5744987081
So unfortunately the ones with sources in your above list cannot be used without substantial rewrites.
Website, Youtube
Reply 2694 of 2696, by zaphod77
Oh ho ho! Midiyoke NG WORKS.
tested with sendsx, settig both midi in and out to the first midi yoke NG port. 2 bytes, sent, 2 byte received.
https://www.hermannseib.com/programs/myokeng.exe
and yes, i have the new stack.
Reply 2695 of 2696, by Falcosoft
zaphod77 wrote on Today, 08:01:
Oh ho ho! Midiyoke NG WORKS. […]
Confirmed!
The attachment MidiYokeNG.jpg is no longer available
I have just tried and with myokeng installed FSMP can use the standalone version of S-MU2000 through a single Midi Yoke NG connection to play back 32/48/64-channel Midi files.
Website, Youtube
Reply 2696 of 2696, by Roland User
I not known when , but I will trying solve and this problem , I want try make in my MIDI Router generate reports about Virtual MIDI ports for system and usage all generated ports )
