First post, by sdw
Hello
I am trying to get an Ungermann Bass NIU-180 FAB 13304-00 NIC from approximately 1987 working in my xt clone. Very cool card with an onboard 8086 CPU. Does anyone have the software to make this work? After trying Crynwr ubnicpc.com I found out that this card does not take a normal packet driver like every other card I have used. I believe it needs net/one software components. I have not had much luck finding it.
file.php?mode=view&id=249489
https://theretroweb.com/expansioncards/s/unge … nn-bass-niu-180
https://forum.vcfed.org/index.php?threads/ung … 1/#post-1516874
file.php?mode=view&id=249494
file.php?mode=view&id=249493
The attachment 990-U275-0152_Ungermann-Bass_Net_One_1984.pdf is no longer available
Any help would be appreciated.
Thank you
