First post, by Glitch58
Hello, got this Vaio last week but previous owner damaged the internal speakers connector and I want to do a bypass using Kynar wires - I saw that there ale soldering points for ferrite beads, which someone desoldered too, I guess it's just for signals L+, L-. R+ and R-. But the problem is with identyfing which signal is each ferrire responsible for.
The curious fact is that there is no separate Amp IC on board - signal comes directly from codec with coupling capacitor
Laptop is based on MBX-104 motherboard, which lacks any public available schematics
Here are some photos of audio section on motherboard:
