Reply 20 of 21, by AncapDude
AncapDude
Offline
- Member
I am also planning a K6-3 Build with a V3 3000 AGP. What I managed in a quick test bench try is to run Bleifuss Rally (Screamer Rally) in Plain DOS 3DFX Mode without issues. You just need the correct glide2x.ovl that works with the V3. That should do the trick for all dynamically linked games. Statically linked games may not work tough and need a V1/V2 instead.
