First post, by HwAoRrDk
I acquired a Promise DC4030VL-1 IDE/floppy controller card a while back, but until recently I didn't have a fully-working VLB system to try it on. But I do now!
However, I have no idea what I'm doing with this card. 😅 What do I need to do to actually use this thing?
I checked the jumper settings using a reference I found on The Retro Web, and I believe I have them all set correctly. Floppy is enabled, VLB speed set to 'normal' (i.e. not 50MHz - I'm using it on a 486SX-25 system), and IRQ set to 14 (which is otherwise free).
When I boot the system, the card's BIOS ROM shows a Promise-branded message after the usual RAM check, but then hangs for about 10 seconds, then very briefly shows a message I can't fully read that says something like "Get configuration failed", and then the system proceeds to start normally from floppy. (I presume the floppy interface on it is pretty much self-contained.)
I was expecting that the DC4030VL-1 maybe would have its own kind of configuration BIOS, much like some SCSI controllers, but if it does, I don't know how you get into it. I found a manual online for the EIDE4030plus (a later model, I gather) and it says that you press F2, but it also says that the on-screen messages says so too. I see no kind of key press prompt to enter a config BIOS.
Maybe this is because I don't currently have any hard disk connected to it? I have a couple of old 3GB and 6GB HDDs in storage, but the only thing I have available right now to hand is a CF-to-IDE adapter, but I can't use that because the connector on it is keyed (with a plugged pin), and the IDE connectors on the DC4030VL-1 are not (no missing pin). 😞
I'm also confused about drivers. Seems like there is a whole slew of stuff. Like, there's a ton of stuff on Metropoli. What do I need? I'm aiming to use this thing under DOS and Windows 3.1.
