First post, by feipoa
Does anyone know how to force or restrict DMA/UDMA modes on a Promise Ultra 66/100/133 TX2/TX4 PCI card (PDC20268 chipset)? This host adaptor doesn't have a BIOS that I'm aware of, but runs a firmware that isn't adjustable on the front-end.
The problem I've been running into is with respect to CF card adaptors which plug directly into the Promise card (no cable).
I am using a CF-IDE adaptor which has two CF card slots on the same adaptor. One CF card is Master, the other is Slave. When I boot up, sometimes the Promise firmware sets UDMA 5 mode for both cards, sometimes it sets UDMA 2 mode for both cards. If it sets UDMA 2, everything works fine, but if it decides the cards are UDMA 5, I am unable to boot the system and receive a "disk error".
The Primary CF card is a Lexar 8 GB with "UDMA 7" written on it. The Slave is a Transcend Industrial 64 GB.
If I boot with only the Lexar, it always detects as UDMA 2 ("you don't have an 80-pin cable"). If I try to boot with only the Transcend Industrial card, it always detects as UDMA 5.
If I use a different CF-IDE adaptor, that is, one which uses a cable, the Lexar (Transcend not connected) will detect as UDMA 2 if using a 40-pin cable, and will detect as UDMA 5 if using an 80-pin cable. If it detects/sets as UDMA 5, I will get disk error at boot. Note, it will detect as UDMA 6 if used in a Promise Ultra133 card.
If I use a 40-pin cable with only the Transcend Indistrual, Promise sets it to UDMA 5. If I use a 80-pin cable, Promise sets it to UDMA 5. Something is clearly wrong here. The Transcend is forcing UDMA 5 always?
Ideally, I was hoping there was a simple means to tell the Promise controller to always use UDMA 2 mode, regardless of what is detected in pin 34. Is pin 34 only used to identify what the CF card's speed capabilities are, or is it also utilised for other activities when there are, both, Master, and Slave cards on one IDE port? My understanding is if 3V/5V is detected on pin 34 of the IDE port of the Promise controller, it should set UDMA 2 or lower. If it detects GND on pin 34, it should set UDMA 4 or higher.
Looking at this cable detection scheme, and using a cable-less dual-port CF-IDE adaptor:
The attachment Detection_of_IDE_UDMA4_and_higher_using_80-pin_cables.png is no longer available
1) In a power off state, should it be possible to measure 15 K-ohm between pin 34 on the Promise card and GND? I do not measure anything here. It was either open circuit, or in the mega ohms. What about a power-on state?
2) In a power off state, should it be possible to measure 10 K-ohm between pin 34 on the CD-IDE adaptor and 5 V, that is, assuming the CF card is plugged into the adaptor? I do not measure anything here. It was either open circuit, or in the mega ohms. What about a power-on state?
3) If I connect a 10 K-ohm resistor between IDE pin 34 on the Promise and 5V, will the Promise card always assign UDMA 2 mode or lower?
My workaround so far has been to use the two CF cards in two distinct [cable-less] CF-IDE adaptors and on different IDE ports of the Promise card. This sets the Lexar to UDMA 2 and Transcend to UDMA 5. The Transcend is not the boot drive and it seems to otherwise work at UDMA 5 speeds within Windows. Because I'm using a socket 3, there is no discernable difference in benchmarks between UDMA 2 and UDMA 5.
4) If I had been using a faster motherboard, I would be concerned that the Lexar was not able to boot at UDMA 5/6 speeds. Any idea why I am getting disk error when it is set to UDMA 5 on a socket 3 board?
Thanks everyone!
Reply 1 of 17, by The Solutor
Back in time I fought a lot with such things, trying to solve the problem from the HW side, as you noticed isn't that simple.
So I tried Uniata which has parameters to force/ignore what the cable connections tells, still no joy.
So I asked help to Alter (the author of uniata) which was very kind (I hope is going well, given he is ukrainian), he spotted a bug in his driver that affected exactly such parameters, at least on the controller I was using, and fixed it in no time.
The controller I was using wasn't a Promise, but support for Promise TX controller should be there, so give UniATA a try (look at the documentation about the parameters, as I don't remember the sintax, too much water passed under the bridges since then).
Reply 2 of 17, by feipoa
Thanks for your input. For this particular scenario, if a CF card won't boot (because the controller sets UDMA mode 5), there won't be a software opportunity later to adjust the UDMA mode.
Reply 3 of 17, by The Solutor
Yes my problem was actually the opposite, the card didn't work as its best capability.
Whatever you can try what happens using something like this
https://www.amazon.com/40-Pin-Female-Drive-Ex … 698&sr=8-3&th=1
Technically a 40 wires cable should be enough to degrade from UDMA mode 5 to slower modes.
And anyway, having a cable makes easier to check various scenarios w/o doing anything definitive to the boards
Reply 4 of 17, by maxtherabbit
What do you measure between ground and pin 34 in a power off state with the transcend card only installed into the adapter?
Based on symptoms it seems clear that the transcend is holding pin 34 to logic low. If you want to overcome that externally you'd want to know how strong the pull down is
Reply 5 of 17, by feipoa
Power-off, with the Transcend in a cable-less CF-IDE adaptor, it is open circuit between pin 34 and 5V, and open circuit between pin 34 and GND.
Power-on, using a cable-less CF-IDE adaptor, on Promise's Secondary port, the voltage between pin 34 and GND,
Transcend: 0.78 V, which becomes GND once Promise firmware is loaded
Sandisk: 0.89 V, which becomes GND once Promise firmware is loaded
Lexar: 1.34 V, which becomes GND once Promise firmware is loaded
Curiously, with the Laxar CF card connected to Promise's Secondary port, it decides that it is UDMA 5 now. Sandisk also UDMA 5. This controller cannot make up its mind. I tried a different controller card, but the results were the same.
Should I pull-up pin 34 to 5V on the CF adaptor with 10K, even though it appears that the Promise controller is pulling pin 34 low once the firmware loads? Or maybe becausethe controller senses a low logic level, it decides to then pulls pin 34 low.
Alternately, can we hardcode UDMA 2 in firmware somehow? Firmware attached.
The attachment Promise_Ultra100_TX2-v2.20.0.15.zip is no longer available
Reply 6 of 17, by maxtherabbit
That's certainly curious. I would be concerned about the "disk error" with the proper speed mode set more so than the flaky detection without a cable in the mix.
Reply 7 of 17, by feipoa
I'm not too concerned that the Promise Ultra 100 card cannot boot to my 8 GB Lexar CF card when set to UDMA mode 5. It seems like the Promise card is goofing up on auto selection of UDMA speeds and this is the likely culprit. I was hoping to find a way to set UDMA speeds manually rather than rely on auto detection. The detection is flakey even with a cable in the mix - Transcend stayed at UDMA 5 with a 40-pin cable used. Swapping IDE ports changes things further.
Reply 8 of 17, by The Solutor
You're using the normal FW, right?
Maybe you can try to flash the RAID one (IIRC, just a single resistor needs to be added to make the upgrade possible).
The ATA mode detection is likely the same, but still worth a try, given the time required and the cost are next to zero
Reply 9 of 17, by feipoa
Yes, I'm using the standard Promise firmware. Can the Promise RAID card work in non-RAID mode, which I think is called JBOD.
Are you referring to using the Promise FastTrak 100 TX2 BIOS? That card contains a PDC20270 chip, while my card contains a PDC20268 chip. If you are referring to using the Promise FastTrak 100 model, that chips contains a PDC20267. Which RAID card uses the PDC20268 chip?
What if I flash the BIOS and the card becomes unresponsive? The EEPROM chips are soldered on.
I decided to test several different types of modern CF cards in a late P3 system (Asus TUSL2-C) with onboard UltraDMA 100 support (mode 5). Using a cable-less CF-IDE adaptor, all CF cards get set to UDMA mode 2 by the BIOS, which is expected since an 80-pin cable isn't present. So, something is off with the detection algorithm or hardware on Promise Ultra 100 TX2 cards when it comes to using these CF adaptors.
Reply 10 of 17, by The Solutor
It's hard to a answer in 2026 enshittified internet, and my memory is not that invincible.
But yest according to one of the few survived links I found the ultra 66 is moddable (to fast trak66)
https://arstechnica.com/civis/threads/promise … -to-use.968793/
P.S. possibly isn't even protected and no pull-up / pull-down resistor is needed
For the details I'm afraid you have to dig in archive.org
Assuming you have the correct bios there are two options
1)the card is a recent revision, then requires the electrical mod, in that case, no mod=no flash.
2)the card is not protected, then you can flash at your liking, and the card will work
Perhaps it isn't a PC, it's a card.
Under windows the card works even w/o any bios at all, the bios extension is needed to be bootable and to configure boot order and raid configuration.
Reply 11 of 17, by maxtherabbit
The pin detection is not the only thing that determines what speed is set. The pin detect is a quick pass/fail which determines whether speeds above 33 are allowed, but the targets still negotiate the maximum speed with the controller.
That is to say, if the card is negotiating UDMA 5, it should work at UDMA 5. And the flaky pin detect behavior of the card is probably not the only problem here
Reply 12 of 17, by The Solutor
maxtherabbit wrote on 2026-09-29, 13:00:
The right DMA speed/protocol plagued the Win95/win98 days.
Just open hdc.inf of any 2000+ windows to get the idea of how many corner cases are contemplated/blacklisted/tailored for a single specific device
And I guess the Linux kernel has a similar list, even if I never dug in that part of the kernel
Those blacklists/whitelists are the reason why the headaches of w9x days are mostly gone
Reply 13 of 17, by maxtherabbit
The Solutor wrote on 2026-09-29, 15:03:
The right DMA speed/protocol plagued the Win95/win98 days. […]
Whether or not the storage driver for the OS behaves properly is a totally different issue from failing to even load the boot sector
Reply 14 of 17, by The Solutor
maxtherabbit wrote on 2026-09-29, 15:07:
It's very likely the same issue, in the current case you just face it earlier
Reply 15 of 17, by feipoa
In light of the diagram I attached earlier, I decided to add a 10K resistor between 5V and IDE pin 34. The CF card was detected as UDMA 2, as hoped, but the output on pin 34 was still higher than desired (4.6 V). It looks like the PDC20268 chip on the Promise card runs at 3 V, so I was hoping to get pin 34's voltage closer to 3 V. Swapping the 10K resistor for a 33K resistor, brought the pin 34 voltage down to 3.2 V. This would imply that the resister to ground on the Promise card was around 66K.
Note that I am branching resistor off of a Schottky diode, which measured at 4.84 V (5.12 V - 0.28 V).
Now, any CF card I plug into the CF-IDE adaptor gets detected as UDMA 2, even the pesky Transcend Industrial card which kept running at UDMA 5, even with a 40-pin cable. So far, everything works fine with this resistor in place. I have not tested this in a dual-CF Master/Slave IDE adaptor because I wasn't sure if the CF cards have any communication on pin 34 in this configuration in Master/Slave config.
Benchmarks on the Transcend Industrial with UDMA 5 were identical to that when set to UDMA 2, that is, about 30,000 Kbyte/sec.
The attachment Force_UDMA2_or_slower_on_cableless_CF-IDE_adaptor_and_Promise_Ultra100_TX2_1.JPG is no longer available
The attachment Force_UDMA2_or_slower_on_cableless_CF-IDE_adaptor_and_Promise_Ultra100_TX2_2.JPG is no longer available
Reply 17 of 17, by douglar
feipoa wrote on 2026-09-30, 13:45:
That seems pretty close to the theoretical max for UDMA2. You probably are not going to get much better than that with UDMA2.
I got speeds a little faster out of my CF170 at UDMA5 on an NForce2, but it was only a 4GB device, so likely had different flash chips and maybe different limitations.
Re: Small capacity SSD PATA/SATA benchmarks
