First post, by dreamblaster
I made a new waveblaster board, PicoPango
available soon at https://serdashop.com/products/picopango
It features 2 synth engines (one more is under development, will come with software update) :
  • GU-Wave wavetable sound voiced with the GU GS bank: 261 instruments, 13 drum kits, reverb and chorus
  • FM-Classic: FM style general midi, 1990s style
  • Switch easily between engines, using the Pangoset utility.
  • 48-voice polyphony, all 16 MIDI channels
  • USB-MIDI, class compliant: no drivers needed on Windows, macOS or Linux
  • 3.5 mm stereo line out
  • Compact PCB : 34mm x 34mm
  • High quality Stereo DAC
  • Powered from the sound card or from USB
  • Easy firmware updates over USB: drag and drop a file (RP2350).
The attachment PicoPango_connections.jpg is no longer available
The attachment PicoPango_front_wb2.jpg is no longer available
New X2GS TE & X16GS sound card : https://www.serdashop.com/X2GS-TE ,
Thanks for your support !
Reply 1 of 2, by keropi
mmmm fresh wt 😁
will add it to the ever growing collection !
🎵 🎧 ⏳ ⚡ SoundVision PRO,MK1869 , PCMIDI MPU , OrpheusII , Megacard and 🎶GoldLib soundcard website
Reply 2 of 2, by Angus.Young
Looks great.. will Grab one from SerdaShop when available.
