Hi all,
I just registered here. Very interesting forum!
Thanks to SupraGSX for sharing the Forceware driver.
I installed it on a Quadro P620, but unfortunately it gives the error: “This device cannot start (Code 10).”
Then tried on a GT730 before reading on GitHub that the driver would never work on a GP107 card.
Also tested on a GTX960, where the driver installs correctly, but there’s no signal on the DP port, while on the HDMI port the max resolution that works correctly is 1920x1080.
All tests executed on a real machine with a fresh XP install.
