First post, by alpm
Hi folks, my VGA is utterly strange. I haven't used it in a while, but I'm seeing strange behaviors when in 3D mode (OpenGL, DirectX).
dxdiag 3D tests is broken after version 8, and it reports an insufficient amount of available memory.
For instance, here is how Quake looks like:
The attachment quake_1.PNG is no longer available
The attachment quake_2.PNG is no longer available
R5MEMID shows just artifacts past test 4, though it reports all memories are "fine". Tests #2 and #3 briefly shows a black screen and reports a pass as well.
Any ideas? Can you help?
R5MEMID version 1.03, (c) Copyright ATI Technologies Inc, 2006
Log file generation enabled to .\R5MEMID.LOG ...
Extended logging enabled ...
Reference data file (RDF) loading disabled ...
Configuring AGP subsystem for AGP3.5 compliant chipset ...
AGP configuration successful ...
AGP system size = 256MB
AGP window size = 4MB
AGP window address = C0000000
AGP logical address = C0000000
AGP gart address = 00014000
AGP gart entries = 00000400
AGP common memory = 4194304 bytes
sba = ON
rate = 8X
AGP_CNTL = 00000800
[1] Mem production test FB001
[2] Mem production test FB063
[3] Mem production test FB064
[4] Mem production test FB065
[5] Mem production test FB066
[6] Modified FB088
[7] Modified FB091
[1 ] Mem production test FB001 : PASS
[2 ] Mem production test FB063 : PASS
[3 ] Mem production test FB064 : PASS
[4 ] Mem production test FB065 : PASS
[5 ] Mem production test FB066 : PASS
[6 ] Modified FB088 : PASS
[7 ] Modified FB091 : PASS
TEST RESULT SUMMARY:
RV530/M56 (0x71c2) detected.
256M video memory.
Test suite ran 1 of 1 times.
Checking test status array ...
No failures detected.
