First post, by MrFlibble
@starlord succeeded in liberating the shareware shmup Baller! And Forget, but the game does not play sound effects properly in DOSBox even with the correct hard-coded IRQ:
starlord wrote on 2026-10-06, 15:41:
```I found the cause. BALLER!S.EXE has a complete Sound Blaster engine: it mixes 16 channels into a 1 KB buffer and plays it by […]
```I found the cause. BALLER!S.EXE has a complete Sound Blaster engine: it mixes 16 channels into a 1 KB buffer and plays it by DMA, refilling the buffer from the card's interrupt (IRQ). The credits saying "Keiner" is just out of date. Two bugs in that engine explain why DOSBox stays silent.
1. IRQ 5 is hard-coded. The game reads the base, IRQ and DMA from the BLASTER variable and attaches its handler to that IRQ. But the code that switches the IRQ on at the interrupt controller always enables IRQ 5: it computes 1 shl 5 instead of using the IRQ it just read. eXoDOS/DOSBox defaults to IRQ 7, so the game listens on IRQ 7 while only IRQ 5 is switched on. Playback starts with a 1-byte transfer meant to trigger the first interrupt, and with IRQ 7 that interrupt never arrives. That gives exactly "no sound at all".
2. It never turns the speaker on. The game never sends the DSP command that enables output (D1). A real SB16 ignores that command and is always on, and so is DOSBox's SB16, but an SB 1.x/2.0/Pro stays muted. So it can only work as an SB16.```
```The first round showed I'd missed something: the IRQ and speaker bugs are real, but there's a third problem that silences the game in every setup.
What I missed: the game doesn't put its sound buffer in normal memory. It writes the sound into segment B000h, the old monochrome video memory, and points the Sound Blaster's DMA there. The code first allocates a proper buffer, then throws it away and uses B000h. The author probably did this because the proper buffer didn't work for him.
On a VGA card in the 320×200 256-colour mode (mode 13h) the game uses, that memory area doesn't exist. The game mixes the sound into nothing, and the card plays back an empty buffer, so you hear silence. That explains all five silent tests. It probably worked for the author because he played it in a Windows 95 DOS box (the PIF files point that way), which may well make that area behave like normal memory.```
Is there any way to circumvent this via a TSR or something? @ripsaw8080, any ideas?
DOS Games Archive | Free open source games | RGB Classic Games
Reply 1 of 1, by ripsaw8080
Rank DOSBox Author
DOSBox Author
The sound seems to work in 0.74 with IRQ 5. This is due to the 0xB000 segment being mapped as general RAM in VGA graphics mode, so it can be used with DMA paging.
Some games probe video memory segments for hardware detection, concluding that a monochrome board (MDA or Hercules) is present if the 0xB000 segment can be written to and read from. In order to prevent the games from erroneously detecting a monochrome board, SVN maps the 0xB000 segment as empty in VGA graphics mode, and forks may have adopted the change.
Maybe a memory manager like EMM386 or QEMM was used to map 0xB000-0xB7FF as RAM, supporting what the game is doing with that memory, but I'm not sure that would work.
