Thanks LSS, you are running another newer version that relied on new symbols, I added those it might work now. I addresses some keyboard mapping issues between OS personalities and other fixes. Also fixed executing across personalities in the different versions.
On the other hand, sound underrun messages still spams the log a bit (as seen in the NDN log), even though sound is working without apparent issues.
I wonder if there are options to mitigate it somehow.
Besides, it seems I cannot launch any other OS ports of NDN from the DPMI32 version of NDN, complaining about "This program must be run under xxx" (xxx being Win32 or OS/2 depending on the port type). Perhaps this is a limitation.
And by the way... I wonder if it's somehow possible to make Windows or OS/2 processes run fullscreen, as "Make window/Make fullscreen" doesn't seem to have any effect on Windows or OS/2 processes (such as NDN ports) at the moment.
