Retro backup software?
First post, by Matth79
Planning my 3 way retro fleet, DOS, 98, XP and thinking, how do I back them up, once everything is set up how I want?
One tool? Seems unlikely from a starting point of P133 with 32MB, though I guess the DOS system could be zipped and then mTCP to a NAS. Don't mind making the "DOS" system into 95/98 "DOS" if that opens more options.
Also, hoping to cover perhaps on-system quick restore to cover software foul-ups, and off system restore if HDD dies.
Reply 1 of 9, by DosFreak
If you want images then Clonezilla should work on a P1 try the 486 or 586 builds, you'll need PLOP though. Also the older the better probably.
If the amount of data is too much then saving the image to a removable drive would likely be faster.
486
Clonezilla-live-2.2.1-25-i486
586 (Try older builds if too slow)
clonezilla-live-2.4.2-61-i586.iso
686 (Latest version for 686 machines)
clonezilla-live-3.2.0-5-i686.iso
https://sourceforge.net/projects/clonezilla/f … table/2.4.2-61/
Make your games work offline
Reply 2 of 9, by nali
On old computers Plop often must be config to use Usb 1.1 mode.
Clonezilla can also be booted from the network, for example using AllInOne floppy, using a basic network card.
Reply 3 of 9, by mbbrutman
The best type of backup here is a partition image backup, not a file level backup. A partition image backup includes the FAT table, directories, hidden file, system files, etc.
If Clonezilla will work, that is what I would use. If not, something older like Power quest Drive Image works great on older machines and it also does image backups.
Reply 4 of 9, by crusher
I also have a 3-way fleet with DOS, 98 and XP computer 😉
For the DOS and 98 one I had boot discs or sticks with Norton Ghost. Backup was done onto USB media.
That worked but was very slow. The backup took more times the more games I put on the systems.
The XP one I could boot with AOMEI Backuper stick and even use USB 3.0.
After I modified the systems and changed from internal hard drives (SSDs in my case) to removable racks, the backups became very comfortable and fast.
I can easily take out the SSD, plug it into an USB adapter and use it as external drive on a modern system with every backup software you like. Because of USB 3.0 it is much much faster as doing backups with the original system.
As a side advantage you can use this method for large file transfers.
Maybe it is a point you want to consider in your planning.
Reply 5 of 9, by theelf
Norton Ghost
Reply 6 of 9, by Matth79
Thanks, some good suggestions, they don't mention the old versions of Clonezilla on the main site, so I just went 192MB, no can do!
There is a NAS in my plans too, so the network assisted idea may be a runner.
Reply 7 of 9, by zapbuzz
powerquest diskimage 5 was my favourite from DOS to early XP but your on another planet entirely.
Reply 8 of 9, by thierry
I'm using the client-server version of Norton Ghost; I need to see if it works on the 386. I have a new server, so it's a good idea to set up the backup server again.
Test results are coming out this weekend!
Minimum Client Hardware (DOS Mode):•
CPU: Intel 386DX or higher (Note: Ghost 2003 requires at least a 486 or Pentium class chip due to processor instruction sets; Ghost 6.0/7.0 can still run on a 386).
Reply 9 of 9, by Jo22
I've used to use Acronis TrueImage. Versions 7 to 9, mainly. They both support Windows 98SE and XP, at very least.
The software includes a builder for a live CD (-or floppy diskset-), which has both a Linux/DOS "mode" (DOS for fallback through BIOS access for HDDs) and runs on a Pentium with 64 MB of RAM onwards.
(The original installation CD is boot-able, too).
Acronis TrueImage 10 was apparently the pinnacle of its time.
