SoftGPU: OpenGL + DirectX + Glide driver for Windows 95/98/Me
Reply 180 of 188, by LSS10999
LSS10999 wrote on 2026-09-15, 08:32:
Not sure which option did SoftGPU's "QEMU std driver" correspond. On my Win98 VM, SoftGPU installer automatically chose "VirtualBox 7.1.8 and newer" profile but it complained because it reported the GPU being a Legacy non-PCI VGA, so the installation simply copied necessary files to the destination.
When manually updating the default "Standard VGA" driver from Display properties the only matching driver is the "VESA ISA Adapter". It installs and works. At 1280x800 I'm seeing decent framerates with DirectDraw and Direct3D tests, and the UI drawing seems responsive enough, so for now it kind of works on QEMU 11 just not optimal.
EDIT: In my current test case it seems after installing vmdisp9x shutdown is kind of broken... I have to force power off or reset and deal with ScanDisk on next boot. Exact cause is not yet clear.
Searching a bit online led me to this. Apparently QEMU's PCI bus implementation is not correctly detected by Win98 setup so it was configured as a non-PCI machine. Manually updating the "Plug-and-Play BIOS" (with a yellow exclamation mark) as "PCI bus" allowed the PCI stuffs to be detected, which also installed the PCI counterparts of certain devices (VGA and IDE controller), but I need to clean the non-PCI residues (existing legacy drivers) as the PCI ones would not function due to resource conflict.
PS: Shutdown still doesn't work correctly with SoftGPU installed. After a few more hard resets I kind of having borked the whole system (VFAT Device Initialization Failed). Guess it's time I start things over, preferably using QuickInstall. Maybe I should also fiddle with some other options to modern ones (like Q35/SATA) since I definitely needed some patches (namely patcher9x for the TLB invalidation bug that happens even in VMs) and the system would have already been patched to the point of being usable with more modern configurations anyway.
EDIT: Nope... looks like QEMU's Q35/SATA config doesn't work for QuickInstall. Win98SE fails to boot (hangs) after finishing hardware detection phase.
shadowmage wrote on 2026-09-15, 10:39:
One problem with QXL for retro games is that it does not support some lower color-depth modes such as 256-color or 16-bit modes, and some older games need those.
I do have a WinXP VM using QXL and it indeed doesn't work for some games, though it worked pretty well for browsing the web using MyPal in terms of responsiveness. When I tried "State of War" it refused to launch so I brought in a DDraw wrapper (PAL-DDraw) which allowed the game to run but the mouse pointer isn't working correctly. Maybe I can give your instructions a try if I have time.
As for Win2000 I don't really have a use for retro gaming. It was mainly used for running some old development environments. VBEMP already worked for enabling additional color options just I'm not sure if the drawing is responsive enough.
A question: When you used VBEMP with wrappers instead of official QXL driver for XP, did you keep the VM's video type as "QXL" or you used "VGA" or other options instead?
Reply 181 of 188, by shadowmage
@LSS10999
I don't use QXL. I run QEMU directly from a shell script and use the standard VGA device:
#!/bin/bash
qemu-system-i386 -monitor stdio
-rtc base=localtime
-display sdl -m 512
-L pc-bios
-cpu host
-M pc,accel=kvm,usb=off
-device VGA
-device AC97
-device virtio-net-pci,netdev=net0
-netdev user,id=net0
-drive if=floppy
-device virtio-blk-pci,drive=boot0,bootindex=1
-drive id=boot0,if=none,file=winxp.qcow2
-cdrom xp.iso
-boot menu=on
So with VBEMP NT I simply use -device VGA, not -device qxl.
As for the Windows 98 shutdown problem, this is a known Win9x issue under QEMU. It happens regardless of the display driver and is not caused by vmdisp9x.
There is a simple workaround. Before shutting down Windows, open command.com in full-screen mode, type:
exit
Then shut down Windows normally. After doing that, shutdown works.
This can also be automated. Create C:\WINDOWS_STARTUP.BAT containing:
@echo off
exit
Then create a PIF for it, set it to Full-screen and Close on Exit, and put it in Start -> Programs -> StartUp.
I also use a ready-made Win98 qcw image from Archive.org which already has the shutdown problem fixed and works very well with QEMU, so most of the time I don't need to deal with this manually.
Reply 182 of 188, by LSS10999
Win98 QuickInstall 1.0.1a works correctly with default i440FX/IDE machine config and can be booted successfully after install.
- PCI bus is correctly configured.
- QEMU USB Tablet is correctly detected so mouse integration works with virt-manager.
- e1000 network adapter driver is installed out-of-box.
- AC97 (ICH6) sound driver can be installed from Extra Drivers (driver.ex), using the Avance one.
- SoftGPU correctly detects QXL and informs me that it is not supported (yet).
- Some other PCI devices exist but not important for my usage, so I kept them in Other Devices (without drivers).
Looks like QEMU STD VGA indeed corresponds to "VGA" video type. This option is available in virt-manager for QEMU 11. Changing video type to VGA from QXL will make SoftGPU correctly detect QEMU STD and install correct drivers using "QEMU (software 3D only)" profile.
The driver works correctly after reboot. DXDIAG also works correctly for both DDraw and Direct3D and I'm getting some decent framerates here.
And the system shuts down fine this time. Maybe the issue has been addressed with the QuickInstall image.
Reply 183 of 188, by The Solutor
LSS10999 wrote on 2026-09-15, 13:32:
Probably that and other problem you faced depends on setup done in acpi mode or not (IIRC win98 FE has the ACPI mode disabled by default, and you need a switch)
setup.exe /p j
After it's installed you can still enable it adding a registry DWORD named ACPIoption in
HKEY_LOCAL_MACHINE \Software\Microsoft\Windows\CurrentVersion\Detect
Then redetect all your HW
Maybe Quickinstall did that for you (I never used It so, I'm just guessing)
The above is not a small detail, it literally transform Win98 from Win9x on steroids to a relatively modern OS.
Win98SE should do all of that automatically, if it thinks the HW is up the task, something that not always happen.
Reply 184 of 188, by 2mg
Is 3Dfx/Glide still locked to that one specific qemu build it yourself thingy?
Would it not be possible to somehow wrap Glide instead, be it inside VM with SoftGPU, or on that VM?
Reply 185 of 188, by The Solutor
2mg wrote on 2026-10-04, 22:05:
That's the usual QEMU pass-through workaround
In VMware and VBox you can use the included glide support and/or something else, say glidos works very well, but I think also nglide or similar will work
Reply 186 of 188, by 2mg
The Solutor wrote on 2026-10-05, 01:22:
So SoftGPU OGL/DX > Glide wrapper, all inside a VM, would work?
Reply 187 of 188, by The Solutor
2mg wrote on 2026-10-07, 00:34:
It has it's own 3dfx support, not for dos apps anyway, I used glidos to run tombraider (works both with OpenGL and D3D backend), Unreal works depending the patch level with in d3d, glide and opengl mode, i think that things like nglide or other alternative glide wrappers may work as well
Then there are small variations between VMware and VBox (vbox is more mature/fast in general it has even FSAA enabled by default) vmware has a bit more glitches (say no blink videos on tombraider) but has the huge advantage that you can install the vmware tools (custom install, everything except the VGA driver), while VBox never had proper additions for W9x.
No FSAA by default in VMware (I guess for compatibility with older versions say 15 and before) but in recent releases it works OK.
Also keep in mind that VBox emulates the support for the VMware VGA and recent VBox releases can use either the V9 or V10, with different level of capability and compatibility (you can't use the GUI to choose between them, either edit the config file or use the command line)
For everything else the wikis are pretty informative, as there are a lot of options to experiment with.
Reply 188 of 188, by 2mg
The Solutor wrote on 2026-10-07, 00:56:
It has it's own 3dfx support, not for dos apps anyway, I used glidos to run tombraider (works both with OpenGL and D3D backend), […]
Is Glidos the only DOS Glide option, and is it only for TR?
Windows can probably do as you say nGlide or even dgVoodoo, if for some reason built in Windows Glide doesn't work.
I'm aware of feature list, it's nicely explained.
The lack of FSAA could potentially be overcome with Lossless Scaling upscale or running the VM with (DL)DSR, right?
