mwdmeyer wrote on 2026-10-09, 11:21:
When I installed NFS2SE it didn't install the glide exe so needed to copy manually from CD I think. Did you get any specific error message?
My next version will make it much easier to submit issues.
I dont have internet connected to that older pc at the moment, actually nfs2se did start and error is at exit, nfs2se 3dfx demo has error at start.
Velocity9x settings report
Version: 0.15.0
Build: 11d348f
Adapter: ATI 3D Rage XL AGP
PCI ID: 1002:474D
Revision: 65
Video memory: 8128 KB
Mini-VDD build: 11d348f
2D (GDI): CPU (Windows DIB Engine)
Last DirectDraw test: Complete, 3 of 3 pixel checks pass
Active mode: 800 x 600 x 16 bpp
Core / engine clock: Unavailable
Memory clock: Unavailable
Clock detector: ati-mach64-unavailable-v1
Driver stage: enable-ok
Framebuffer: Active - linear aperture mapped
Last GDI test: not run
Mode switching: Live, any depth
Direct3D: Hardware (the chip's own engine) (SYSTEM.INI Direct3D=0)
VSync: Not yet stamped by DirectDraw (SYSTEM.INI VSync=2)
Direct3D DDI: Not yet stamped by DirectDraw (SYSTEM.INI Direct3DDdi=0)
Baseline modes: 640x480, 800x600, 1024x768 at 8/16 bpp and 60 Hz
Runtime modes: 19 published
Mode scan: state=1 listed=40 queried=40 cached=30 flags=0107
Drop reasons: 12,2,0,0,0,9,0,0,0,0,7,0,0
EDID recommendation: 1280x1024 reason=edid-preferred
Inventory generation: 123
Registry sync: ok (generation 109)
Rendering: Windows DIB Engine (software GDI)
DirectDraw: CPU fill and copy, page flip
Mini-VDD callbacks: VESA, monitor power
Last report sent: none
NFS2SE 3Dfx Demo error at start
NFS2SEAD caused an invalid page fault in
module <unknown> at 0000:6c095210.
Registers:
EAX=00000000 CS=0187 EIP=6c095210 EFLGS=00010202
EBX=00000001 SS=018f ESP=006ffb84 EBP=00c58bc0
ECX=006ffb88 DS=018f ESI=00000002 FS=0d47
EDX=00000000 ES=018f EDI=00000008 GS=0000
Bytes at CS:EIP:
Stack dump:
0049a804 00562f10 00000000 00000001 00424274 00c40208 00000011 00476141 65465c2e 61746144 5c63705c 5c747241 64696c53 745c7365 656c7469 7366712e
NFS2SE error at game exit (menu not visible)
NFS2SEA caused an invalid page fault in
module KERNEL32.DLL at 0187:bff7b9a6.
Registers:
EAX=00000000 CS=0187 EIP=bff7b9a6 EFLGS=00000246
EBX=00000006 SS=018f ESP=0070fc50 EBP=00000002
ECX=c1580a10 DS=018f ESI=01650210 FS=0e77
EDX=00004de0 ES=018f EDI=00000001 GS=0000
Bytes at CS:EIP:
ff 76 04 e8 13 89 ff ff 5e c2 04 00 56 8b 74 24
Stack dump:
00000000 004883c7 01650210 c1580a10 00004de0 004a0eda 00487cd1 00000006 c1580a10 004df04a 00000060 00498aa1 00000018 0049acd4 004a959c 00000000
Best ATi Rage3 drivers for 3DCIF / Direct3D / OpenGL / GLUT / DVD : ATi RagePro drivers and software
33+MiniGL / OpenGL Win 9x dll files for all ATi-Rage3 based cards : ATi RagePro OpenGL files
