Reply 60 of 71, by SupraGSX
RedCharles wrote on 2026-10-10, 00:48:Forceware.382.69.10-6-2026 750Ti - DP - XG27UQDMS (Asus 4k Oled) […]
750Ti - DP - XG27UQDMS (Asus 4k Oled)4k 60hz works with DP
2560x1440 works @ 120hz
1920x1080 works @ 240hz
1024x768 works @ 240hz2560x1440 froze up @ 165hz.
2560x1440 went black @ 144hz. Windows XP said it worked, but I didn't see it.Thank you SupraGSX. You have made my dream come true. Thank you.
https://github.com/SupraGSX/Forceware-382.69/ … 0-09-high-clock
No problem!
Please try this linked version it should be even better
10-6-2026 is outdated and there's been several improvements since then.
Install new version using custom install then clean install to overwrite the older version.
