Abit KT7A (KT133A/VIA686B), Athlon XP Mobile 2500+
Reply 400 of 413, by FullYes
Calolo wrote on 2026-10-13, 17:09:
Hello […]
Hello
I have flashed the BIOS of my KT7A v1.1 to A9 (modded for Athlon XP) to use a mobile Barton 2400+.
I need to press reset when the PC cold boot, then the CPU is well recognized but limited to 1666MHz (12.5 x 133).
Has someone found a solution/BIOS option to make it boot directly?
Also if I strap CPU pins to enable high multipliers, how can I access the 3x for DOS slowdown?
Thank you.
Since you have a mobile Barton. You should be able to use pciset (to make setmul work on a KT133A) and setmul commands in your autoexec.bat to make the multiplier whatever the CPU will allow
My XP-M 2800+ will only recognise multipliers up to 16x, probably because it’s a late one.
Link to my thread which has a link to the post about pciset
Re: Socket 7 and Socket A shenanigans. 2 (or possibly 3) retro builds. Attempting to build 600MHz 430TX
I don’t have a kt7a but I have same chipset on a board made by Soltek. It seems to have a lot of the same quirks
I can’t help with the reset trick. The Soltek board POSTs fine with a Barton installed. I used bios patcher to enable the board to recognise the CPU, but it still posted without this patch. Just said “unknown CPU”
in my experience, modifying the socket of the CPU to change the multiplier caused more problems; the system would only post with 17x multiplier, this was too fast for any CPU I had at the time. (2266Mhz) now I have an XP-M I can get to 2350-2400MHz with 16x multiplier by increasing the FSB
System 1: K6-3+ 600MHz! MS-5158 (430TX), Voodoo3, AWE64
System 2: Athlon XP-M 2800+ SL-75KAV (KT133A) FX5200
System 3: 775i65g (work in progress) FX5900XT
System 4: i7-2600k, P8P67-M, GTX 460
Reply 401 of 413, by Calolo
FullYes wrote on 2026-10-13, 18:29:
Since you have a mobile Barton. You should be able to use pciset (to make setmul work) and setmul commands in your autoexec.bat […]
Hello […]
Hello
Thank you.
Since you have a mobile Barton. You should be able to use pciset (to make setmul work) and setmul commands in your autoexec.bat to make the multiplier whatever the CPU will allow
Thanks for your reply.
I have tried the pciset command before "cpuspd m3" and now it runs @400MHz 3x133 !
So it will still work even if I strap the CPU pins to enable high multipliers?
DOS/98SE : PIII-S 1400/C3 1200, GA-6BXC 2.0, 256MB PC133 C2, GeForce 2 Ultra, Voodoo2 12MB, Audigy1 Platinum Ex, ESS1688, SSD 128GB
XP/7 : i5 3750k, 8GB DDR3 1600, GTX 280 1GB, Radeon X1950 XTX, SSD 512GB
Reply 402 of 413, by FullYes
You don’t need to ‘strap’ anything. Just try a higher multiplier with your setup as it is now. You should be able to set it to at least the highest rated for your CPU just by using software
So, mine as it is now can be set from 3x to 16x. Modification of the motherboard is not needed 😎👍
Reply 403 of 413, by Calolo
FullYes wrote on 2026-10-13, 19:49:
You don’t need to ‘strap’ anything. Just try a higher multiplier!
I have tried using pciset and cpuspd on my Barton 2400+, I can only go up to 13.5x (1800MHz), no overclocking using multiplier.
Reply 404 of 413, by FullYes
Ok. What you describe is how my cpu behaves as well - it does not let you exceed the stock multiplier with software. Since I didn’t try this CPU in my board when I modified the board, I cannot say if you will succeed or not, because I put it back to standard now due to the strange posting behaviour.
Another user; Mr.Hunt Did succeed in modifying his Soltek kt133a motherboard (same as mine) to work with his xp-m 2800+ with 17x multiplier. So perhaps it will work for you as well
The thread where we discussed this in more detail is here
Re: Socket 462 SL-75KAV weird posting behaviour after pin mod
Reply 405 of 413, by luk1999
Did you guys try to use Wcpuid to change mobile multipier on XP-M?
It worked for me on newer (KT400 or 600) mobos.
P4 3.4E, P4C800-E Dlx, 1 GB, X800 PRO 256 MB, SB Audigy, XP SP2
A1.4, A7V133, 512 MB, R8500LE, FM801, ME
P3 600, AX6BC, 128 MB, GF2 PRO 64 MB, ALS100+, 98SE
K6/266, MS5149, 64 MB, Virge 4 MB, V1 4MB, ESS1868, 95 OSR2
Reply 406 of 413, by FullYes
luk1999 wrote on 2026-10-15, 10:37:
I will look into this - thanks for the suggestion!
Edit - i am seeing some information in this thread suggesting that not being able to set a multiplier above the rated multiplier for the CPU is normal for XP-M. I am wondering if it is only possible to aim higher with an early CPU? like with Bartons/Thoroughbred CPUs made before week 38 '03 (or whenever it was)
Reply 407 of 413, by Calolo
Has someone else noticed some memory errors with a Barton CPU on KT7A (v1.1) ?
Every good RAM sticks I tried make some errors on test #6 of MemTest86 with my XP-M 2400+. In the BIOS I used "load optimized settings" only.
The attachment IMG20261015145214.jpg is no longer available
I don't have this problem using a Duron 700 and SDRAM @133Mhz, same BIOS configuration as the Barton. Unfortunately I don't have other Athlon XPs to try.
The attachment IMG20261015163325.jpg is no longer available
Reply 408 of 413, by luk1999
FullYes wrote on 2026-10-15, 11:32:
Max mobile multipier depends on bridges configuration (L6 I think). It was explained on FAB51 page: https://fab51.biosbude.de/cpu/barton/athlon-e23.html
If you use regular Athlon XP or Sempron and connect bridge responsible for mobile mode, then you should be able to set mobile multi in range 3x-24x.
Calolo wrote on 2026-10-15, 15:03:
Maybe try to rise slightly IO Voltage to 3.4-3.5V.
Reply 409 of 413, by mockingbird
I will test and report back to you.
(Decommissioned:)
Reply 410 of 413, by Calolo
mockingbird wrote on 2026-10-15, 20:03:
Thank you.
I have found that the number of errors reported by Memtest86 depends on the vCore and vIO.
I tested all the voltages between 1.45v and 1.65v for vCore and between 3.3v and 3.5v for vIO.
Increase vIO results in more errors. For vCore 1.575v is the minimum to use.
So the sweet spot is 1.575v and 3.3v, in this configuration Memtest86 report no errors!
I don't know if the problem is with my motherboard or the CPU, I will keep testing to confirm that this configuration is fully stable.
Reply 411 of 413, by Shiftyy
Hello […]
Hello
Thank you.
Yes, I found a solution. I have outlined it in my previous post:
Re: Abit KT7A (KT133A/VIA686B), Athlon XP Mobile 2500+
Shiftyy wrote on 2025-12-17, 12:57:
Another weird thing, after completing the 5-4 PIN mod, I can now boot the computer without needing to press restart at all. Even after plugging in the power.
Here is what you should do, from my experience:
Shiftyy wrote on 2026-01-08, 18:26:
So to summarize, with my Barton-M 2500+, I am using 9x multiplier (With the 5-4 PIN mod, so it's actually set to 17x multiplier), 133 FSB, CPU voltage set to 1.65v (May be able to lower it to somewhere between 1.6v-1.65v, but 1.65v is 100% stable so haven't bothered yet), 3.50v I/O voltage and the rest of the BIOS settings are set to what is recommended on Paul's website.
Reply 412 of 413, by mockingbird
Calolo wrote on 2026-10-15, 20:50:
I have found that the number of errors reported by Memtest86 depends on the vCore and vIO. I tested all the voltages between 1.4 […]
No, that's not right. I will have concrete information for you later, but I can tell you from memory that the XP-M should be able to operate at stock voltage without errors.
I trust you've replaced the capacitors? What did you use for replacements?
(Decommissioned:)
Reply 413 of 413, by Feallan
Hi, not sure what's the best thread to ask, so I thought I would post here. I recently acquired two motherboards, one is Abit KT7A-RAID 1.3 and the other Soltek SL-75KAV. I wanted to build a PC based on one of these motherboards, paired with an Athlon XP-M. Which one would be a better choice? Both boards require replacing several capacitors
