Reply 20 of 33, by ntalaec
zyzzle wrote on 2026-09-11, 21:08:The attached contains neopaint unpacked, and it still runs.
The unpacked version runs fine. I was able to register the program using the serial.
zyzzle wrote on 2026-09-11, 21:08:Falcosoft wrote on 2026-09-06, 11:56:The main problem with patching NeoPaint is that it seems it tries to defend itself against patching (I think it's because of the registration related routines).
It's PKLITE packed. You can unpack it and then the disassembled code is clearly valid but the unpacked exe cannot be started anymore. Most likely some kind of CRC check but I could not find exactly where it is.The attached contains neopaint unpacked, and it still runs. But you also need the neopaint.ovr file. It starts just fine, and can be modified.
I'm not sure which offsets in the raw uncompressed binary to attempt to patch in order to get rid of the multiply-by-3 and divide-by-3 code. Perhaps the modifications needed to get 32-bit VESA modes propery displayed are not in the .exe but in the overlay file.
Yep, this one runs perfectly and it is somewhat bigger than the one I got when I used UnPKd.exe to get the unpacked version. Can I ask what unpacker you used to get this?
The main code parts related to VESA modes enumeration and validation are the same but I could not find the relevant 24-bit only drawing routines in either one...
Most likely the drawing routines are really in the Borland Pascal style overlay file.
OK, I have found the drawing routines in the overlay file. The funny thing is there are already implemented 32bpp drawing routines besides the 8,16 and 24bpp routines 😀 So instead of rewriting the drawing routines I simply redirected the callings from the main executable to the 32-bit ones in the overlay. This way I got a working canvas with good shapes and colors but all interface elements became garbled. Also the PXC saving cannot produce proper PCX files anymore... So it seems this is a harder job than we hoped.
Falcosoft wrote on 2026-09-12, 11:54:Yep, this one runs perfectly and it is somewhat bigger than the one I got when I used UnPKd.exe to get the unpacked version. Can I ask what unpacker you used to get this?
CUP386.EXE /7 NEOPAINT.EXE
Falcosoft wrote on 2026-09-12, 15:54:OK, I have found the drawing routines in the overlay file. The funny thing is there are already implemented 32bpp drawing routines besides the 8,16 and 24bpp routines 😀 So instead of rewriting the drawing routines I simply redirected the callings from the main executable to the 32-bit ones in the overlay. This way I got a working canvas with good shapes and colors but all interface elements became garbled. Also the PXC saving cannot produce proper PCX files anymore... So it seems this is a harder job than we hoped.
Very, very strange the 32bpp modes were apparently coded but not implemented?! There's got to be a reason why. The strange misalignment of the interface in your redirected 32bit mode seems to point to some kind of hard-coded memory offsets being used for the interface icons, etc. A very kludgy way of coding. As the program is a flat 16-bit Borland Pascal .exe (I think), there may be a good reason for it, but I can't seem to figure it.
zyzzle wrote on 2026-09-12, 20:32:Falcosoft wrote on 2026-09-12, 15:54:OK, I have found the drawing routines in the overlay file. The funny thing is there are already implemented 32bpp drawing routines besides the 8,16 and 24bpp routines 😀 So instead of rewriting the drawing routines I simply redirected the callings from the main executable to the 32-bit ones in the overlay. This way I got a working canvas with good shapes and colors but all interface elements became garbled. Also the PXC saving cannot produce proper PCX files anymore... So it seems this is a harder job than we hoped.
It seems I found some helper routines that calculate the coordinate geometry for 32-bit. It fixed the GUI element position problems but also caused the mouse cursor to draw random colored trails. And the 'colored' GUI icons are still drawn in 24bpp. It's rather frustrating 😀
Falcosoft wrote on 2026-09-12, 22:27:It seems I found some helper routines that calculate the coordinate geometry for 32-bit. It fixed the GUI element position problems but also caused the mouse cursor to draw random colored trails. And the 'colored' GUI icons are still drawn in 24bpp. It's rather frustrating 😀
Wow, that's real progress. As I understand you, 32-bpp images will load OK with full 16.7M colors now, but there are those strange "color" trails which corrupt the image when the mouse pointer is rolled over them. May you further illustrate with a screenshot of a truecolor image loaded into the program (something like a color wheel or something showing the full palette)?
Still, if it's now working in 32-bpp VESA modes and / or Intel vBIOSes with your mods, that pretty much makes it "usable" on modern systems, I'd say. But frustrating there are always snags, now something with the mouse routines corrupting the memory somehow?
Your progress of adapting Neopaint to 32 bits is impressive but I doubt that it will be ever usable. The binary maybe has some code for 32-bit drawing but the application itself is designed for 24-bit and I doubt that it will be ever possible to finish the conversion.
Better approach is to run DOSBOX from DOS or maybe modifying the graphic mode of the card. The graphic card maybe supports the 24-bit modes in hardware but does not have the VESA interface to them.
With modification of the mode setting routine (direct register modification) it could be possible to achieve.
Something similar was used to force to use Intel 910/915 to display in 4:3 ratio - https://high-voltage.cz/_dl/EEEfit_1.0.zip
Laaca wrote on 2026-10-03, 10:49:Your progress of adapting Neopaint to 32 bits is impressive but I doubt that it will be ever usable. The binary maybe has some c […]
1. Yep, I came to the same conclusion.
2. I think the situation in case of 24bpp modes are substantially different. I have also written DOS 4:3 aspect ratio correction utility for my T430 (that apparently works with any Intel Sandy, Ivy, Haswell integrated GFX):
download/file.php?id=247684
but the difference is that aspect ratio correction was known to work under Windows, Linux etc. So the mission was to find out how. But 24bpp modes are not supported under any known OS in case of Intel GFX. So the chances are high that support is missing at the hardware level. While 24bpp to 32bpp software emulation with banked frame buffer modes is possible in theory it requires that the VESA program respects the WinASegment and WinSize values reported by the VESA mode. But NeoPaint (and most likely other VESA programs as well) ignores these reported values and always uses 0xA000 and 64KB.
Anyway my theory for a TSR was the following.
1. Reserve 48KB conventional memory as a shadow frame buffer.
2. Report 24bpp mode for the requested 32bpp mode when int10 4F01h is called and also report the segment and size of the reserved shadow frame buffer (instead of 0xA000 and 64KB).
3. Intercept int10 4F05h (bank/window switching) and convert the 48KB 24bpp data to 64KB 32bpp data and write it to the real VGA frame buffer at 0xA0000. Call the original bank/window switching.
If the application draws whole frames this should work.
Aha! I understand your method. It is indeed interresting but it is as you write - the application must draw whole frames. Another possible solution could be to hang on the timer interrupt and update screen after every X milisecond but it would be very CPU demanding.
I grew to hate Neopaint so much that I would rather have sold my soul to the devil than let NeoPaint win.
So I asked AI to solve the problem and on the 6th attempt ChatGPT 6 successfully solved it.
I attach the whole package generated by AI. The patched executable is included.
So here it is a NeoPaint version that works with 32-bit VESA modes instead of 24-bit.
If someone is interested the main breakthrough idea of AI was to differentiate the internal image representation of NeoPaint from the final video buffer representation.
But looking at the patch I still do not fully understand how it achieved this.
It also added new code and finally rebuilt the whole executable so the final executable size is different (about 55KB larger).
But the point is that I do not want to hear about this project anymore. It is not a good feeling to accept that AI is smarter than me...
You're one of the smartest (if not the very smartest) programmers on this forum. This is troubling. Very troubling. That AI could take this ~400 kb DOS executable, do some magic, and spit out a new binary that is 55kb *larger* is not only disconcerting, but WHAT THE HELL takes 55 kb more?! And what the hell took 6 attempts? Maybe AI just got lucky and 54 kb of the extra code is just AI bloat.
All the same, the goal is achieved, but it's a pyrrhic victory to be sure. Thanks for posting it, however.
zyzzle wrote on Today, 00:47:You're one of the smartest (if not the very smartest) programmers on this forum. This is troubling. Very troubling. That AI could take this ~400 kb DOS executable, do some magic, and spit out a new binary that is 55kb *larger* is not only disconcerting, but WHAT THE HELL takes 55 kb more?! And what the hell took 6 attempts? Maybe AI just got lucky and 54 kb of the extra code is just AI bloat.
I completely agree that this is rather troubling. I have to defend AI somewhat since what it did was not random shooting based on luck but absolutely 1st class engineering.
The biggest problem with AI is that it wants to be kind and agree with you at all costs 😀
So the first failed tests can be attributed to my fixation to the flawed concept of finding and replacing all 3-byte pixel routines with 4-byte ones. This proved to be a mission impossible.
The hardest part was to convince it to forget my original presuppositions and find fresh new ideas. After the idea that NeoPaint needs two different pixel sizes at the same time: 3-byte per pixel in its internal images but 4-byte per pixel in video memory AI only needed 2-3 iterations to make a fully working version.
In order to implement this idea simple patching was not enough. It had to write some new conversion routines and supporting helpers (overall 498 bytes). The 55 KB bigger size is due to replacing the original WWPACK-style compressed relocation table with with standard relocations and keeping the existing code at the same image relative addresses. Furthermore there was a need to fill the gap between the existing loaded code/data and the safe location chosen for the new code.
Using its Python environment AI could also use Unicorn to test its new code fragments and the interaction between the new and existing code parts.
https://pypi.org/project/unicorn/
It's crazy but this way AI could:
1. Load actual machine-code bytes from NeoPaint.
2. Configure an emulated 16-bit x86 CPU, registers, stack, and memory.
3. Execute individual routines and compare their output with the expected bytes.
Overall the whole AI collaboration took about 2 hours. Before (not continuously) I spent way more time with NeoPaint. So I have to say this is the future and I have to find a new job and hobby.
Do you remember that once 'computers' were humans (mostly women) who performed long and tedious mathematical calculations?
To this analogy I think in some decades it will be a strange thing that once 'programmers' were humans who actually wrote code in a text editor.
So you were able to understand it after all. Good explanations, and I agree this is the future. Once the genie is out of the bottle...
How long before we can have it code entirely new and novel DOS applications? For example using SMP, or "impossible" tasks like built-in NTFS support and native > 4GiB file access into the DOS kernel itself. Or things like native 4096-byte sector size support, so we can get a full 16TB in MBR. (Of course BIOSes would also need to be modified probably, but it's a great wish to finally break the 2TB barrier in MBR.).
Or, "OK AI: I like this arcade game from the '80s. No DOS port exists. Make me a native x86 DOS port using CWSDMPI. MAME is an emulator, but here's the binary data from the game. Give me a native DOS port, please." And it will do it after the 5th or 6th try...
