First post, by Mondodimotori
Ok, I gotta ask here because this situation is driving me insane.
For really no reason at all, I acquired some P4 and 754 AGP mobos (thiking about a 939 one too) for very very cheap, planning to keep them around just in case. This drove me to look for cheap late AGP cards (2004 onward) to fully utilize the faster CPUs on those boards. This also for no reason at all, since Win98 isn't ideal on those cards, and WinXP is well covered by PCIe options I alredy own.
But just... I can't seem to get a working card in my hands.
I currently went through three cards, all listed as working (one even brand new, in a sealed box):
-A 7600 GS from Gigabyte, new in a sealed box, just DOA, no video output.
-A 6600 GT from XPERTVISION, sold as working, arrived with lots of artifacts and died entirely 15 minutes later.
-Another 6600 GT from Sparkle, sold as working and thoroughly tested, also arrived DOA with no video output.
All of them got for honest prices (and not current inflated prices) and were promptly refunded.
Note that, for the two 6600GT, both the power connector and PCB/chips do heat up even when not displaying video. The 7600GS remains ded cold.
The boards I tested these cards on are:
-ASUS P5P800 SE (865PE chipset)
-Asus K8V-MX (VIA K8M800)
-Asrock 775VM800 (VIA P4M800)
-ABit AB-NF7-S2G (nForce2 Ultra 400)
All supporting AGP 8X and perfectly working with previous generation AGP cards (Tested with several Radeon 9600s, MX 440s, Ti4200s and FX5600)
I even tested different known good PSUs, since those newer AGP cards do need a molex power connector plugged.
The question is: Am I doing something wrong? Is there some caution I should apply to these late AGP cards? Is it the power connector? Or the AGP bridge chip being delicate and taking with it a good GPU and good memory? Am I the one frying good cards? Or maybe some settings on the mobo?
Or is just plain bad luck and I should just ignore late AGP cards, as they are becoming unobtanium by this point (100+€ for a 6600gt is insane), and aren't really worth it for either Win XP (get a PCIe) and Win98 (get an older AGP card).
Reply 1 of 19, by Mondodimotori
Guess I know why the latest Sparkle 6600 GT isn't working... The AGP bridge chip cracked either when it was removed from the previous system or during transit. I bet the memory and the GPU itself are still fine. I wonder if I could take the AGP chip from the other 6600GT that artifacted and put it onto this one...
The attachment cracked die.jpeg is no longer available
Reply 2 of 19, by shamino
How are the capacitors on that NOS 7600GS card?
Some of them had caps that would fail in storage. If they have "FZ" stamped on them, they're Sacon FZ. Every one of those I've seen is dead and exploding now, even if they were never used.
Reply 3 of 19, by Mondodimotori
shamino wrote on 2026-10-17, 10:41:
Visually they look fine... The card is just dead cold no matter what platform/PSU I use.
The attachment photo_2026-10-17_18-04-26.jpg is no longer available
The attachment photo_2026-10-17_18-04-26 (2).jpg is no longer available
Reply 4 of 19, by RandomStranger
Visually fine and fine are two very different things. I met a lot of visually fine caps that were dead.
Reply 5 of 19, by Mondodimotori
RandomStranger wrote on 2026-10-17, 18:04:
Yeah, I know... What I don't know for that card if it's worth it to have it repaired. Or maybe I can use it as a test to finally practice in replacing capacitors.
Would be the first time in two years that I find myself with an electronic that's completelty dead due to bad caps. I was able to avoid the problem until now.
Reply 6 of 19, by kixs
Once I had a bad PSU. It worked but VGA cards didn't show output. If I remember correctly only Nvidia cards didn't work - like Geforce 4 Ti4600 - I was pretty upset. Changed the PSU and all worked fine 😁
Visit my AmiBay items for sale (updated: 2026-03-23). I also take requests 😉
Reply 7 of 19, by shamino
Those caps are Nippon KZJ and some kind of Sanyos.
KZJ are a "controversial" series from an otherwise reputable manufacturer, but I don't think they're nearly as bad as the kind I was talking about, so I think that's probably not the problem.
Power could maybe be involved - if you can, try to get a measurement of the voltage rails with a multimeter while it's trying to boot (ie under load). I know you've tried several boards and video cards, but it's possible some of those cards are more demanding on rails that the other cards don't care as much about.
I notice the plastic cover is still on the DVI port. I've run into some cards - and the one I remember for sure was a 7600GS - which didn't play well with my KVM (are you using one?) I had to use a DVI->VGA adapter on the DVI port to see the video output. The card didn't default to VGA even though that's how I had it hooked up.
If you have an adapter handy, try testing both output connectors in case it's just not detecting correctly which port to use.
Same suggestion for any of the cards that have dual outputs. Since the 7600GS is staying cold, it does seem like that card just isn't getting powered for some other reason.
Reply 8 of 19, by Mondodimotori
shamino wrote on 2026-10-17, 23:16:
Those caps are Nippon KZJ and some kind of Sanyos. KZJ are a "controversial" series from an otherwise reputable manufacturer, bu […]
I did performs all the usual tests: Different boards, different PSUs, different molex connectors on every PSU and both VGA and DVI output. I just put all the cap back after testing it months ago since, being NOS, it came with the box and all accessories.
I found another 7600GS for a "not that bad" of a price, we'll see how this acts up. But I'm starting to feel I just got extremely unlucky: One 6600GT has the AGP bridge chip busted, one was just on it's way out when I got it, and this one is, simply, new old stock that was probably ded the day it left the factory.
The guy that sold me that 7600GS did tell me that he had a PC part store, and that was some leftover inventory he still had after retiring. I literally got it for 15€ plus cheap shipping. Probably the cheapest 7600GS I ever saw on ebay recently.
I'm also waiting to hear from a repair store if they're able to transplant the VGA Bridge chip from the ded 6600GT to the one that has the chip broken, because I bet the rest of that card is perfectly working.
kixs wrote on 2026-10-17, 23:03:
Yup, tried that to no avail with all those cards. I have two or three PSUs I use for testing. They're nothing to write home about, but they get the job done. One is from a decomissioned CAD workstation, one is from an unknown brand but it did work fine for almost a full year on my XP retrobox (E8600+HD6970) before being replaced for a reputable Corsair. Then I also have a couple of Enermax from 2008/09 that I got from scrapped PCs. I used only one of them a bit while performing tests on a Win7 box, but not knowing the full history of those units, I put them into permanent storage.
Reply 9 of 19, by Ydee
Some bad capacitors don't show a bulge at the bottom (top), but instead push out the rubber gasket at the bottom near the leads (causing them to rise above the PCB). What do these look like?
Reply 10 of 19, by Mondodimotori
Ydee wrote on 2026-10-18, 10:00:
AFAIK normal. But if you want I can pull it out of storage again and take another picture. At this point I may as well learn how to recap and use that card to do so.
Reply 11 of 19, by AlexZ
Nothing unusual. I would estimate failure rate of late AGP cards to be about 35% and that is those that seller confirmed to be working, not those sold in unknown condition.
I had 2 passive Gigabyte 6600 GS, both artifacting. I salvaged heatsinks and threw them away. I have one 7600 GT that I know for sure worked fine for a few months, then after a year in storage became unstable. But it has visually bad and leaking caps, so maybe just recap is needed. It convinced me to sell all my late AGP cards and stick with PCIe only.
That's how I ended up with s754 and PCIe. It's best to forget about fast AGP cards. I have multiple similar PCIe cards - GTX 275, GTX 260 core 216. These tend not to be too expensive, aren't as special as GTX 285.
You should be using AGP only for Windows 98 and in that case you can use GeForce 4 MX 440, GeForce FX 5200/5500 and those survive everything.
Pentium III 900E,ECS P6BXT-A+,384MB,GeForce FX 5600, Voodoo 2,Yamaha SM718
Turion 64 MT-40@2.4Ghz,Gigabyte GA-K8NE,2GB,GeForce GTX 275,Audigy 2ZS
Phenom II X4 965,Gigabyte GA-MA770-UD3,8GB,GeForce GTX 780
Vishera FX-8370,Asus 990FX,16GB,GeForce GTX 980 Ti
Reply 12 of 19, by Mondodimotori
AlexZ wrote on 2026-10-19, 20:34:
Nothing unusual. I would estimate failure rate of late AGP cards to be about 35% and that is those that seller confirmed to be w […]
Yeah, I guess I will... I still bet on a couple more AGP cards that should came into the mail soon, just because they were cheaper than average. But yeah, I've got plenty of 775 MOBOs in storage (those are like roaches, you always get them) and PCIe cards, including an 8800 GTX and a GTX 280, several HD 48** and more. And they usually are dirty cheap used.
I'll stick to MX440s and, at max, Ti4200s for windows 9x gaming, leaving the XP era to PCIe.
Reply 13 of 19, by Joseph_Joestar
Mondodimotori wrote on 2026-10-16, 09:14:
-A 7600 GS from Gigabyte, new in a sealed box, just DOA, no video output. -A 6600 GT from XPERTVISION, sold as working, arrived […]
It's possible that some of those cards were made around the time when manufacturers started switching to lead-free solder (relevant link). That process wasn't as refined yet, which occasionally resulted in subpar soldering.
Pair that with the tail end of the capacitor plague era, and you get a "wombo combo" effect, which can reduce the lifespan of such cards.
My retro stuff
Reply 14 of 19, by Ydee
The GeForce 7xxx series with the G7x GPU falls within the “bumpgate” period, and the higher operating temperatures of this GPU only increase the likelihood of failure. The GeForce 6600 series, however, uses the NV43 GPU, which should be more reliable.
However, if you use adequate (usually aftermarket) cooling, they should all survive. The capacitors can be replaced.
Reply 15 of 19, by Mondodimotori
Joseph_Joestar wrote on Yesterday, 07:48:
That's also possible, a bigger reason to learn how to recap. Shame for the card with a broken AGP bridge, the repair shop I usually go to said that they can't replace it even with a donor card.
Ydee wrote on Yesterday, 08:21:
Oh yeah, the same one that was responsible for both the YLOD on PS3 and RROD on 360, right?
Weird that it happened on a new boxed card though... That usually happens after several cycles of thermal stress.
Reply 16 of 19, by Ydee
I don't think “bumpgate” is to blame in the case of your 7600GS. Can you measure whether voltage is coming from the GPU and memory VRMs, and what the voltages are?
Reply 17 of 19, by Mondodimotori
Ydee wrote on Yesterday, 11:01:
Unfortunately I can't, I have yet to purchase a multimeter.
Just in case, I'll ask now: If I were to sell these broken cards for pennies on ebay (and the likes), is there a forum section where I could post the listings?
Reply 18 of 19, by Ydee
AFAIK, there is no thread for it, only giveaway.
Reply 19 of 19, by Mondodimotori
Ydee wrote on Yesterday, 12:27:
Ok then, at most I'll up one of these threads of mine about them with just a tip if I'm selling one of those cards, no link or other things. Just to make sure they get in good hands (and not speculators)
