yianom wrote on 2026-10-20, 10:06:Can anyone please provide chip markings ?
I had a look at https://theretroweb.com/motherboards/s/newtec … smt-smt4321-22a and could not see anything.
I suspect the VRM is an EZ1085 or similar and you should be able to figure out the pins by measuring the voltages. Once installed check the correct voltages are supplied to the CPU socket before installing any CPUs.
Google came up with:
The SMT4321-22A is actually an uncommon Socket 3 486 motherboard manufactured by NewTech/SMT (also known as the TS-486 Terminator), rather than a standalone VRM (Voltage Regulator Module) chip.
If you are looking for the VRM chip on this specific motherboard—likely because you are attempting to configure jumpers to run a low-voltage 3.3V CPU (like an Intel 486DX4 or AMD Am5x86) instead of a standard 5V CPU—here is what you need to know:
• Voltage Regulation Design: Many revisions of this board use a standard LT1085 / LM317 or compatible linear voltage regulator chip package (typically in a TO-220 or TO-263 format) next to the CPU socket to step 5V down to 3.3V or 3.45V.
• Jumper Configuration: You will need to locate the specific onboard jumper blocks that route the power through the VRM circuit rather than passing the raw 5V straight to the Socket 3 pins.
When I was adjusting the VRM on my interposer the best coolers I found were https://www.ebay.co.uk/itm/286041915388
