First post, by Paar
- Member
Hi! I'm trying GeForce 4 MX 440 on my Gigabyte GA-7ZM (Via KT133 chipset with 686A south bridge) but cannot make it work. First, the card doesn't work correctly until newer Hyperion branded chipset drivers are installed.
Once it seemingly works, the system freezes after a while whenever a 3D application is running. Didn't help: BIOS update, newer 4.56 Hyperion drivers, newer 45.23 Nvidia drivers, setting AGP driving value to EA, setting 2x AGP, disabling fast writes, disabling sideband addressing.
Maybe it's particular problem with my board, not sure. Radeon 7200 and GeForce 2 Pro both work perfectly.
Any ideas what to try? Maybe some specific AGP driving value?
