HDD and DVD noise
First post, by marxveix
What are the silent IDE HDDs and IDE DVDRW drives or i have to look laptop equipment?
Slot1 Cpu 50x50 fan also noisy i think, HDD is EXCELSTOR J880 and DVDRW is SH-182D.
Bit noisy at the moment for my taste, i would like to lower the noise levels to minimum.
AOpen H340A black case with 200w PSU (No other fan). HDD options and DVD options?
Best ATi Rage3 drivers for 3DCIF / Direct3D / OpenGL / GLUT / DVD : ATi RagePro drivers and software
33+MiniGL / OpenGL Win 9x dll files for all ATi-Rage3 based cards : ATi RagePro OpenGL files
Reply 1 of 4, by gmaverick2k
Software options to slow cd like cdslow. Ide HDD use SD card instead
Main: Z440/E5-1650 V4/3060Ti/64GB/iFi Zen DAC V1/Klipsch ProMedia 2.1 THX/Philips 43PUS8808/12
98/DOS: QDI Advance 10T/Pentium iii-S 1.4GHz/V3 3000/Vortex 2/ESS 1868f/MU90/SC-55/SC-88 Pro/LG StudioWorks 995E
XP: Thinkcentre Edge 72/i5-3570K/GTX 970/X-FiTi
Reply 2 of 4, by marxveix
gmaverick2k wrote on 2026-10-20, 22:23:
I will try cdslow , thanks : http://cdslow.org.ru/en/cdslow/z01-manual.html
Not used SD card before, i have 3.5 ->2.5 ide converter and i can find some 2.5 ide drive, its should be quieter than 3.5 7200rpm.
Reply 3 of 4, by wiibur
Try CDBeQuiet! for DOS (note that for some drives you have to re-run it if you cycle the tray): https://www.a20gate.net/dos-tools/
Reply 4 of 4, by Lylat1an
Your DVD drive is rated at 48x for reading CDs and 16x for DVDs, so if software solutions don't work then a slower drive probably will.
If you want an actual HDD, I think the Seagate Barracuda IV series were the quietest 3.5" models.
I use SD card to IDE adapters in my vintage machines now:
For DOS I use 4GB "Class 10" cards, and for Windows I get the fastest 128GB drives I can justify at today's prices.
