First post, by Hi-FiMan
Upon testing a 6600 GT AGP, 6800 GT AGP, 7800 GS, 7950 GT, and even a Quadro FX 3450 under Windows 2000/XP I noticed things always looked off in 16-bit color games. I first noticed something was wrong in Descent 3 with the "fog" and then I noticed it in almost every other game that renders in 16-bit color; BANDING. This banding was not present on everything like a card that does no dithering at all (GeForce 8+); it seemed to be present only on some textures such as transparencies and maybe some others. The other game I noticed it a lot on was Shogo. You could see banding on the mech arms and some of the skybox textures.
Now common internet mythos says these cards do support dithering in 16-bit color mode but it seems to me that it's somehow incomplete or broken. I've tried multiple drivers from 61.77, 93.71, and even 175.19 and they all have the same behavior. I've also played around with many settings in the driver control panel and rivatuner to no avail. If I install an older card such as a GeForce 5900 Ultra or 4200 Ti, the dithering is all there like one would expect. Interestingly, ATI cards from the time don't seem to have this problem. Radeon X800, FireGL X3, and Radeon X1900 XT cards all render 16-bit color with dither on everything. I did notice 2 or 3 threads on here mentioning broken dither on GeForce 6/7 but the overwhelming consensus seems to disagree. Am I missing something here or should we stay away from these cards for games locked to 16-bit color?
As an aside, driver version 61.77 seems to be the last version that reports supporting 32-bit Z-buffer (without stencil buffer). The only game I know of this matters for is Slave Zero as that game will not render in 32-bit color unless the card supports 32-bit Z-buffers (without stencil buffer). I assume the hardware doesn't actually support 32-bit Z-buffers and just renders with a 24-bit Z-buffer. Only older ATI cards with older drivers seem to support 32-bit Z-buffers but I cannot recall which exact driver; I remember seeing it as an option on Radeon 7200, 7500, 9000, and 9200 cards.
Reply 1 of 8, by Joseph_Joestar
Hi-FiMan wrote on Yesterday, 01:06:
Interesting observations. It never occurred to me that there may be some variations in different games, or even certain parts of the same game. While I haven't tested 16-bit dithering extensively, I did sometimes check it while testing the table fog support of various GPUs. For example, here's how Thief 2 looks on a Voodoo 3 card:
file.php?id=242492
And here's the same screenshot on a much newer GTX 650 Ti:
file.php?id=141042
The color banding is very evident on the latter card. If anyone wants to run additional tests with Thief 2, the save file and testing instructions are available in this post. Also, here's how that game looked on my GeForce 6200 card back when I was running the fog tests.
My retro stuff
Reply 2 of 8, by leileilol
Textures never get dithered, but it's possible that paletted textures got regressed here.
Debian's fucked
Reply 3 of 8, by Trashbytes
leileilol wrote on Yesterday, 23:15:
IIRC this is exactly what occurred with the switch from the FX series to the 6000 series, pretty sure fog table also got nuked around this time with the newer GPUs, may have been earlier.
Games that use the Lithtec Engine are a good way to test both if I remember right. Same with games using the Dark Engine like Thief and System Shock 2.
AI is inevitable, there is nothing you can do to stop it, no Ironman snap to save you from the Basilisk.
Reply 4 of 8, by Hi-FiMan
Yes, textures themselves don't get dithered. It's probably more accurate to say certain blend modes are not getting dithered along with certain types of fog. None of these cards support paletted textures though and I don't think Shogo uses them unless you specify 8-bit textures in the settings which I did not. Also, the Radeon X1900 XT running driver 7.11 renders everything properly with dither and that card also does not support paletted textures. Interestingly, the Radeon also allows me to use MSAA without mucking up the font as long as the alternate pixel center option is enabled.
Reply 5 of 8, by myne
Here's a silly question...
IF the hardware feature was missing, would that make the 6/7 series forever "dead", but with the 8+ having programmable shaders, theoretically they could reimplement the feature accurately?
I built:
Reply 6 of 8, by Hi-FiMan
Trashbytes wrote on Today, 00:46:
Table fog works on GeForce 6/7; however, it just might lack dither but I need to double check that. Shogo uses table fog heavily and it shows up on GeForce 6/7. I should also add that the Matrox Parhelia does not support table fog at all.
When I get some time, I will upload some pictures to demonstrate what these cards are doing and not doing.
Reply 7 of 8, by Trashbytes
Hi-FiMan wrote on Today, 04:21:
Honestly its been a while since I last looked into it all but Geforce 6 and 7 changed quite a bit under the hood from the earlier cards so its certainly worth running a few tests with the cards to determine exactly what was lost/changed.
Shogo and Thief would both work well for this as each engine will quickly let you test for changes.
Reply 8 of 8, by myne
Table Fog & 8-bit Paletted Textures
I built:
