Appreciate that, I'll certainly keep in mind next time a CF starts ghosting me. […]
Trashbytes wrote on Today, 03:03:
Going to go out on a limb here and suggest you test the CF adapter and CF card on another known good system .. I've had a few CF Adapters just give up the ghost yet still be visible to the host system, same with the CF cards .. they do have a reputation for just going dead but appear to still be working.
Fortunately, after much hair pulling it's back to life using FDISK option 5 to set the CF as the "fixed disk" - then deleting the partition completely, and repartitioning, has brought it back to life.
Ultimately this is probably a skill issue on my part; I prepared this partition in Windows 11 a week or two ago which probably did something weird to the partition layout, I thought FAT16 is FAT16 whether prepared in modern Windows or not. Turns out I'm probably wrong.
Weird thing is it actually worked for a week like this. Subsequent Win 11 reparations tonight didn't fix it, but FDISK on the actual Socket 7 machine did the job immediately.
Like I said, a skill issue 😁
