Reply 20 of 30, by slivercr
- Member
A couple of pictures showcasing the difference in NWN. To enable TrueForm you must edit the nwn.ini file in the installation directory, find the line "Enable Truform=0" and change the value to 1. Also, TruForm must be enabled in the ATI drivers. The following are taken at 720p with AA off, notice first the chest and how it gets a bit messed up (1st one is TruForm off, 2nd is TruForm on);
You can also see the "rounding" effect to the head and sleeves of the characters, it may be more apparent in these other shots;
As I said before, its pretty much to each person if they like the way it looks or not. Me I prefer a higher-res with AA and other eye-candy options enabled. I'll try to upload pics of other games.
Outrigger: an ongoing adventure with the OR840
QuForce FX 5800: turn your Quadro into a GeForce
