Reply 420 of 2169, by EvaUnit02
Hi Rcblanke,
I love your frontend, light weight and straight-forward. 😎
Could you please add support for 16:10 resolutions, or at least custom resolutions?
I have fixed aspect ratio scaling enabled in my Nvidia driver and a 1680x1050 monitor. If I don't run Dosbox at the monitor's native res, the output is sometimes horizontally offset - the lower 3rd or so the program being cut-off. This happens when jumping between the actual game and FMV playback, the video is often at a fixed resolution much lower than the 4:3 resolution that I would be running (ie 1280x960). This is particularly annoying in FMV heavy games, like Wing Commander 3.
I'm running XP x64, Dosbox 0.72, Nvidia 8800GT 512MB.
Many thanks in advance.
