vico wrote on Yesterday, 19:20:
Most of the graphical glitches are gone in this version, but there is one that apparently only occurs on LCD monitors (tested on Compaq 1520 and DELL E170SB), the main game screen does not display with the correct colors, the background that should be purple and magenta comes out dark blue and white, and the gray area of the circuit map comes out green.
It looks perfect on CRT monitors.
Tested with my Voodoo3 3000.
This is a bug with the voodoo3 picture timing in 640x400 display mode that has always existed, it may be possible for the game to customise the image timing so it doesn't happen
98/DOS Rig: BabyAT AladdinV, K6-2+/550, V3 2000, 128MB PC100, 20GB HDD, 128GB SD2IDE, SB Live!, SB16-SCSI, PicoGUS, WP32 McCake, iNFRA CD, ZIP100
XP Rig: Lian Li PC-10 ATX, Gigabyte X38-DQ6, Core2Duo E6850, ATi HD5870, 2GB DDR2, 2TB HDD, X-Fi XtremeGamer
