Reply 2720 of 2726, by DOSShark
What can i do to help you further? What information do you need?
EDIT:
If its scummvm specific things:
Im playing monkey island 1 and 2.
In the game specific settings:
-Audio tab: Overwrite global settings (checked) - Musicdevice = Midi Through [ALSA]
-Midi tab: Overwrite global settings (checked) - GM-Device = NONE - mixed adlib/midi mode (checked)
-MT32 tab: Override global settings (checked) - MT32-device = Midi Through [ALSA]
Reply 2721 of 2726, by Falcosoft
DOSShark wrote on Yesterday, 18:21:
How can I reproduce your error simply using Wine + ScummVM on my Linux Mint without all the other stuff you mentioned?
BTW, I do not think that I can do anything anyway since most likely the problem is not with Munt VSTi but with some of the Linux component(s) you use. The hard thing is to identify which one.
Website, Youtube
VST Midi Driver Midi Mapper
Reply 2722 of 2726, by DOSShark
Ok.
(1) Use ScummVM.
(2) Monkey Island 1 and 2.
(3) Set game specific settings in the way i mentioned in my last edited post above.
(4) In your player set midi through port as input
(5) Use your munt vsti Instrument with default settings.
(6) Play the game(s).
(7) On Monkey 1 the intro music is already broken for me.
Reply 2723 of 2726, by Falcosoft
DOSShark wrote on Yesterday, 18:35:
Ok. (1) Use ScummVM. (2) Monkey Island 1 and 2. (3) Set game specific settings in the way i mentioned in my last edited post abo […]
Ok.
(1) Use ScummVM.
Some things should be tried by you first:
1. Play the Monkey Ireland MT-32 Midi file with FSMP first and Munt VSTi loaded. Listen if you can experience the same problem.
2. Eliminate ScummVM from the equation. That is play the Monkey Ireland MT-32 Midi file with another Linux Midi Player through the same port you use with ScummVM so that FSMP + Munt VSTi loaded produce the sound.
Here are the MT-32 versions:
The attachment The Secret of Monkey Island - MT32.zip is no longer available
The attachment Monkey Island 2.zip is no longer available
Website, Youtube
Reply 2724 of 2726, by DOSShark
I dont have a midi file- the music comes directly from the game.
But i tested dosbox and the game doom with your munt plugin and it works perfect - so its a scumm vm thing.
And this is probably out of your hands.
Thanks a lot for taking your time to help me 😀.
EDIT:
Oh - i didnt see you provided 2 midi files.
I only tested Monkey Island 1 midi and like the doom music data from dosbox this works.
Reply 2725 of 2726, by Falcosoft
DOSShark wrote on Yesterday, 18:55:
I dont have a midi file- the music comes directly from the game. But i tested dosbox and the game doom with your munt plugin and […]
EDIT:
Have you also tried point 2. that is not using FSMP for playback but using another Linux based Midi player through the same port as used by ScummVM?
You should also attach a rendered part of the badly sounding ScummVM version as wav/mp3 so that I can have a clue about what you actually hear.
And a screenshot of the Munt VSTi plugin when the bad sound happened ( and a description about at what part it happened).
Website, Youtube
Reply 2726 of 2726, by Roland User
DOSShark wrote on Yesterday, 13:35:
Thanks for replying so fast :) Im using garuda linux with cachyos packages + bore kernel 7.2.11. To launch your player im using […]
Thanks for replying so fast 😀
To launch your player im using bottles with GE Proton 11-9.
System uses pipewire but the midi port im using is 14:0 - midi through port (i thinks its the kernel one) and this one is available as input to your player.
Normal GM midi from dosbox games (Doom, Descent etc.) works great. Even managed the linux openttd to send midi data through aplaymidi to your player - all working flawless.
Its specific to Munt plugin and scummvm linux version.
As variant , you can try use my solution MIDI Router, here very powerful filtration sysex messages , especially for MUNT from FalcoSoft ) , may be this can help you solve your problem and you can use my solution and solution from FalcoSoft )
