Reply 180 of 186, by myne
They might not be fake.
It's trivial in China to copy damn near anything.
Jlpcb might have thrown out a couple, leaked gerbers somehow, or pulled a fast one on you.
Or someone could have copied it based on the pics you posted. Most of the wiring is pretty standard.
The dimensions are known. They have a billion boardviews.
Sorry.
I built:
Reply 181 of 186, by Xardion
Man, that's seriously shady. I mean, is it POSSIBLE that someone could take your schematic and BOM, and build their own board layout from it (possibly with AI assistance)? Given that this is 3 "different" sellers all shipping from the same city, with the same exact ad and the same amount of "inventory", I'm definitely not saying that THIS person did that (these 3 accounts are CLEARLY the same person). It seems like that EISA connector would be hard to source, given how obsolete it is.
Reply 182 of 186, by Xardion
I reported these listings, btw.
Reply 183 of 186, by Tevian
It feels super strange and I'm left wondering if it's just a complete scam. The sellers have thousands of items... I'm almost curious enough to buy one. If they shipped me a copy of my board that would unselecting. But, I'm thinking it's a cash grab and they are counting on a percentage of people not asking for a refund if they sent the wrong items. That is until their account gets shutdown.
I'm sure someone that knows how modern eBay scams work to explain how they make any money doing this.
Reply 184 of 186, by Xardion
It's weird because they have mostly positive reviews, but a relatively low number of sales. My guess is they start these accounts up with a slew of low cost, low effort items, boost their profile, then try to pull some bullshit with bigger ticket items.
Reply 185 of 186, by Adahel
### Architectural Suggestions for BACKWARD2 V2.0 (Maximizing PISA Compatibility)
Firstly, congratulations on getting the BACKWARD2 V1.0 prototype up and running. Demonstrating functional PCI operation from a PC/104-Plus SBC (Single-Board Computer) via the adapter is a significant achievement; furthermore, the work carried out with the "PCI Mapper" card has provided highly valuable data in a real-world environment.
Upon analyzing the measurements collected so far, an interesting pattern emerges:
- PCM-3353:
- IDSEL0 = AD20
- IDSEL1 = AD21
- IDSEL2 = AD27
- IDSEL3 = AD23
- PCM-3370:
- IDSEL0 = AD20
- IDSEL1 = AD21
- IDSEL2 = AD22
- IDSEL3 = AD23
When we add to this your observation that these assignments appear to be BIOS-dependent, it follows that there may not be a single, universal IDSEL configuration that applies to all PC/104-Plus SBCs.
Therefore, I believe the most worthwhile objective for a V2.0 revision is not necessarily to achieve 100% compatibility with every possible combination of SBC and backplane, but rather to maximize compatibility with standard commercial PISA backplanes, while simultaneously reducing reliance on specific hardware—such as the external "PCI Mapper" card.
### Suggested Approach
#### 1. Delegate IDSEL management to the backplane, where appropriate
Commercial PISA backplanes already have the IDSEL assignments for their slots defined via physical wiring (*hardwiring*). Given that the PISA edge connector does not expose independent IDSEL lines, attempting to account for every possible IDSEL variation within the adapter may not be practical.
Instead, the adapter could focus on being as transparent as possible to the PCI bus, while documenting any known compatibility limitations.
#### 2. Incorporating the most useful configuration options into the adapter
The "PCI Mapper" card has already demonstrated the value of configurable routing. A potential direction for version 2.0 (V2.0) would be to integrate a small configuration matrix directly onto the adapter's printed circuit board (PCB):
- Routing for INTA# / INTB# / INTC# / INTD#
- Optional routing for REQ# / GNT#
- Configuration options via resistor-jumpers or 0 Ω resistors
In many cases, this would eliminate the need for a separate "mapper card," while maintaining a relatively simple design.
#### 3. Focusing on compatibility classes rather than universal compatibility
Measurements taken with the PCM-3353 and PCM-3370 SBC boards show that different SBCs may implement PCI slot mapping in different ways.
Rather than attempting to automatically support every possible configuration, it would be more realistic to define and document compatibility classes, such as:
- PISA-compatible standard SBCs
- SBCs that require IRQ remapping
- SBCs that require custom configurations in the PCI Mapper
- SBCs with known BIOS limitations
This would allow users to have a clear expectation regarding the level of functionality they can anticipate. ### Open Question
Based on the testing conducted so far, what do you consider to be the minimum set of configurable features that would cover the majority of PC/104-Plus SBCs on original PISA backplanes?
Would integrating INT# signal routing options suffice, or do you believe additional configuration mechanisms are necessary to significantly reduce reliance on an external PCI mapping card?
In any case, version 1.0 (V1.0) has already validated the fundamental concept. The next challenge is not so much demonstrating that a PC/104-Plus to PISA connection works, but rather determining the extent to which this compatibility can be extended across different SBC and backplane implementations.
Reply 186 of 186, by Adahel
I’m new here; I wasn’t able to edit my previous reply. I promise this will be my last post for the day:
There are some commercial products, as well as an open-source project, that offer solutions similar to your PC/104-Plus to PISA adapter. These might help you fix the issues with your adapter and make it compatible with generic PISA boards:
https://www.douglaspcb.com/index.php/bx-de-104-263-265.html
https://www.douglaspcb.com/index.php/bx-de-104-163-265.html
https://www.artisantg.com/47348-1/RTD-Embedde … dmmJuNAYF6WJOlq
61-pc104skplus2.jpg?t=1774527504
https://www.kontron.com/en/products/pc104-sk-plus2/p86812
1523prod_pc104-sk-plus3-atxsize.jpg?t=1774527505
https://www.kontron.com/en/products/pc104-sk- … atx-size/p86813
https://github.com/tedd-wq/Universal-ISA-Backplane/tree/main
If achieving compatibility with generic PISA cards proves too difficult, another option is to move beyond a purely passive adapter design by incorporating a PCI-to-PCI bridge. While not compatible with everything, this approach would be significantly easier to implement and would offer broader compatibility—albeit with some trade-offs...
Thank you for your attention; I truly hope the project isn't dead and is still under development!
