Reply 40 of 46, by NeoG_
darry wrote on Today, 03:29:
As an optional functionality, configurable line multiplication, if possible, would be very nice. […]
Would it be possible to line double 720x350 --> 1440x700 ( doubling the pixel clock into >25MHz range) and preserving 50Hz output?
Actually, that might be useful for all other supported modes such as 640x480 --> 1280x960 .
If I understand correctly, 320x200 modes are line doubled to 640x400 and then either letterboxed to 640x480 for output or stretched vertically vertically to a full 640x480 picture size, depending on the /V:x setting's value [1] . Alternatively, optionally line quadrupling them to 1280x800, if feasible, would be convenient too.
The main advantage of doing this, other than staying above 25MHz for the pixel clock, would to minimize the amount of scaling done by the monitor and maintain sharpness that might otherwise be lost due to the monitor's scaling algorithm.
I know it's likely an even taller order, but being able to manually tweak timings per mode (i.e. modelines) would really nice too.
Regardless, even if any of this is impossible, impractical, would require too much effort to be feasible or would possibly be of interest to almost nobody (except me), I will be happy to enjoy it as it is.
[1]
Vertical. LINES shows the lines as they are, centred. FILL stretches every mode
over the whole screen height, the way the original monitors filled their 4:3 tubes — a
320x200 game gets its 4:3 shape back
I guess you can output any arbitrary modelines given full control of the HDMI output, but whether they are useful or not depends on whether consumer displays and equipment can actually use them. I suspect the number of screens that would accept a 1440x700@50hz signal is almost zero.
98/DOS Rig: BabyAT AladdinV, K6-2+/550, V3 2000, 128MB PC100, 20GB HDD, 128GB SD2IDE, SB Live!, SB16-SCSI, PicoGUS, WP32 McCake, iNFRA CD, ZIP100
XP Rig: Lian Li PC-10 ATX, Gigabyte X38-DQ6, Core2Duo E6850, ATi HD5870, 2GB DDR2, 2TB HDD, X-Fi XtremeGamer
Reply 41 of 46, by darry
NeoG_ wrote on Today, 03:48:
[1]
As a user of an OSSC and multiple monitors, I can say that monitors, especially newer ones, are often much more flexible on the timings they accept on HDMI/DVI input than their specifications or EDID would suggest.
Case in point, my rather pedestrian 2.5K MSI PRO MP275Q (EDID excerpt [1]) at 1440x700@50hz, in forced 4x3 mode :
The attachment 0.png is no longer available
The attachment 1.jpg is no longer available
The attachment 2.jpg is no longer available
[1]
Monitor
Model name............... MSI MP275Q
Windows description...... MSI PRO MP275Q
Manufacturer............. MSI
Plug and Play ID......... MSI40C3
Serial number............ [OBFUSCATED]
Manufacture date......... 2024, ISO week 1
Filter driver............ None
EDID revision............ 1.3
Input signal type........ Digital
Color bit depth.......... Undefined
Display type............. RGB color
Screen size.............. 600 x 330 mm (27.0 in)
Power management......... Active off/sleep
Extension blocs.......... 1 (Unknown type)
DDC/CI................... n/a
Color characteristics
Default color space...... Non-sRGB
Display gamma............ 2.20
Red chromaticity......... Rx 0.648 - Ry 0.330
Green chromaticity....... Gx 0.319 - Gy 0.617
Blue chromaticity........ Bx 0.150 - By 0.071
White point (default).... Wx 0.313 - Wy 0.329
Additional descriptors... None
Timing characteristics
Horizontal scan range.... 30-155kHz
Vertical scan range...... 48-100Hz
Video bandwidth.......... 430MHz
CVT standard............. Not supported
GTF standard............. Not supported
Preferred timing......... Yes
Native/preferred timing.. 2560x1440p at 60Hz (16:9)
Modeline............... "2560x1440" 241.500 2560 2608 2640 2720 1440 1443 1448 1481 +hsync +vsync
Standard timings supported
640 x 480p at 60Hz - IBM VGA
640 x 480p at 67Hz - Apple Mac II
640 x 480p at 72Hz - VESA
640 x 480p at 75Hz - VESA
800 x 600p at 56Hz - VESA
800 x 600p at 60Hz - VESA
800 x 600p at 72Hz - VESA
800 x 600p at 75Hz - VESA
1024 x 768p at 60Hz - VESA
1024 x 768p at 70Hz - VESA
1024 x 768p at 75Hz - VESA
1280 x 1024p at 75Hz - VESA
1280 x 1024p at 60Hz - VESA STD
1440 x 900p at 60Hz - VESA STD
1680 x 1050p at 60Hz - VESA STD
EDIT: While I haven't tried this specific resolution on my Philips 252B9, I have tried a number of oddball ones with various timings successfully.
EDIT2: Sorry for the crappy cellphone photos
EDIT3: No visible frameskipping according to my eyes and vsynctester.com either.
Reply 42 of 46, by jmarsh
darry wrote on Today, 05:20:
You're not going to get frameskipping when the monitor is being fed less frames than its native rate.
Reply 43 of 46, by dreamblaster
The first few serdavision cards are sent out, so no longer cards available for immediate shipping.
The next batch will be ready in approx 2 weeks, if interested go to https://serdashop.com/products/serdavision-hdmi
New X2GS TE & X16GS sound card : https://www.serdashop.com/X2GS-TE ,
Thanks for your support !
Reply 44 of 46, by darry
jmarsh wrote on Today, 07:27:
Frameskipping was not the appropriate word to use in this scenario. I was looking for any potential motion related artefacts and saw none.
Regardless, I would not expect to see any issues, especially not on a monitor that supports VRR and arguably does not have a "native" rate, but there was no harm in checking, as I hardly ever run this monitor at 50Hz.
Reply 45 of 46, by KVM Nerd
dreamblaster wrote on Yesterday, 20:42:
KVM Nerd wrote on Yesterday, 15:20:
Will it also be able to output the native resolutions, for example 720x350 and/or 720x348 at roughly 50 Hz for Hercules cards, or just the mentioned resolutions? TIA!
720x350 at about 50 Hz isn’t possible over HDMI: its pixel clock (about 16 MHz) is below the 25 MHz minimum for HDMI/DVI, and most screens wouldn’t accept it anyway. Programs never notice the 60 Hz, because they see the card’s own retrace.
From what I know it should absolutely be possible using pixel repetition, which does exactly what it says. If enabled, pixels will be sent multiple times (for example x2 or x4) and the corresponding info field will tell the sink that it is enabled, so it can discard the redundant pixels accordingly. This way, the pixel clock would simply be doubled and be well over 25 MHz. This is a native HDMI feature.
Why not hook it up to a KVM switch?
Reply 46 of 46, by Tiido
Pixel repetition is the way HDMI spec calls for handling all the low resolutions that would fall below the minimum pixel clock limit. Only problem may be the GPIO on the RP2350 not being able to move fast enough on the doubled speed (HDMI/DVI freq on the output signals is 10x the pixel clock)
