RetroGC wrote on Today, 12:09:
Problems persist, I've done exactly the same.
Maybe it was 6.4 test as it was me to ask for single channel recordings 😀
Aldo
Offline mode has nothing to do with single channel recordings. If I understand your problem properly it's not related to single channel recordings but to offline mode. And offline mode did not exist in version 6.4.
If was introduced with 6.5 test version here:
Re: Falcosoft Soundfont Midi Player + Munt VSTi + BassMidi VSTi
So to make things clear: Your problem happens only in offline mode or also when you use single channel recordings in online mode?
I'm asking since you said the problems happened since version 6.4 but as I said version 6.4 only knew single channel recordings but not offline mode.
BTW, offline mode can also be used without recording. It does not make much sense to use this mode for playback only but it works. And for testing you can try that offline mode itself is enough to trigger your problem or recording is also needed.
Anyway, I do not know how to help you since as you could see in my test video I could not reproduce such problems. I also repeated the test on my Win 11 installation and it worked perfectly. So the problem is specific to your system.
Do you have another PC or OS to test offline mode?
