Reply 100 of 110, by costa
giulio wrote on Today, 02:28:For the SC-88/88pro, dumping the socketed eprom is enough
thanks, actually AFAIT, reading an old thread in this forum:
About Roland Virtual Sound Canvas 3
it seems SC-88 Wave ROMs were released even here and in that thread also the de-scrambling sequence was found. does, the 88Emu need scrambled or de-scrambled dumps?
also, in that same old thread here:
combining with the few documented information here:
https://github.com/dsp56300/gearmulator/blob/ … .md#rom-loading
it seems some (or the same?) Wave binaries are found in the "SCCore.dll". anyway, as a newbie, I still think a little better documentation on that part is needed. I have SC-88 and SC-88Pro - I guess I will dump all I can from their PCB and try to build myself some "map" what is what.
giulio wrote on Today, 02:28:For the SC-8820 and SC-8850 you will need to load a firmware upgrade that dumps the internal roms and the wave rom. It works only though on early units that don't use mask rom. For the late ones without the updater you'll probably need to do some microsoldering.
as far as I imagine it such approach uses some kind of Trojan-FW that makes the dump possible and I presume that Trojan-FW is not publicly available. so, I guess, that's out of questions. I have 2x (or 3x, don't remember exactly) 8820 units, need to check my storage room - at the moment cannot tell if anyone of them is using not masked-rom version of the mcu or not. I also have 1x SC-D70...
