Cant make cd-rom work under dos.
First post, by Danilo_Dias
Hi! for some reason i cant make my cd-rom work on dos, i want to assign letter E: for it, tried many things, what i'm missing on my autoexec and config?
im putting the commands here
many thanks!
AUTOEXEC
SET SOUND=C:\PROGRA~1\CREATIVE\CTSND
SET BLASTER=A220 I5 D1 H5 P300 E620 T6
SET MIDI=SYNTH:1 MAP:E MODE:0
SET CTCM=C:\WINDOWS
C:\PROGRA~1\CREATIVE\CTSND\AWEUTIL /S
keyb br,,C:\WINDOWS\COMMAND\keyboard.sys
@ECHO OFF
PROMPT $p$g
PATH C:\WINDOWS
SET TEMP=C:\WINDOWS
GoTo %config%
:EMC
:XMC
:CMC
LH C:\WINDOWS\MSCDEX.EXE /D:OPTICAL
:EM
:XM
:CM
LH C:\WINDOWS\CTMOUSE.EXE /R2
:E
:C
CONFIG.SYS
[COMMON]
DOS=HIGH,UMB
FILES=40
BUFFERS=40
LASTDRIVE=H
[menu]
menuitem=EMC, Expanded memory + Mouse + CD-ROM
menuitem=XMC, Extended memory + Mouse + CD-ROM
menuitem=CMC, Conventional Memory only + Mouse + CD-ROM
menuitem=EM, Expanded memory + Mouse
menuitem=XM, Extended memory + Mouse
menuitem=CM, Conventional memory only + Mouse
menuitem=E, Expanded memory
menuitem=X, Extended memory
menuitem=C, Conventional memory only
menudefault=EMC,10
[EMC]
DEVICE=C:\WINDOWS\HIMEM.SYS /TESTMEM:OFF
DEVICE=C:\WINDOWS\EMM386.EXE RAM
DEVICE=C:\WINDOWS\CTCM.EXE
DEVICEHIGH=C:\WINDOWS\VIDECDD.SYS /D:OPTICAL
[XMC]
[CMC]
[EM]
[XM]
[CM]
[E]
[X]
[C]
Reply 1 of 26, by Horun
Have you tried using the mscdex /L: switch ? It specifies the drive letter you want to assign the first CD-ROM drive.
Try: LH C:\WINDOWS\MSCDEX.EXE /D:OPTICAL /L:E
Reply 2 of 26, by Danilo_Dias
Horun wrote on Yesterday, 15:59:
yes but didnt worked, weirdley when im in dos and manually type
mscdex /D:optical /E
it works perfectly but i cant make it work on the autoexec
Reply 3 of 26, by gmaverick2k
get VIDECDD.SYS and place into c:\drivers folder
Add the following:
Config.sys:
DEVICEHIGH=C:\DRIVERS\VIDECDD.SYS /D:MSCD001
Autoexec.bat:
MSCDEX /D:MSCD001
This worked for me. From Philscomputerlab
Main: Z440/E5-1650 V4/3060Ti/64GB/iFi Zen DAC V1/Klipsch ProMedia 2.1 THX/Philips 43PUS8808/12
98/DOS: Shuttle SK41G/AthlonXP 2200+ 1.8GHz/V3 3000/SuperQuad Digital/MU90/SC-55/SC-88 Pro/LG StudioWorks 995E
XP: Thinkcentre Edge 72/i5-3570K/GTX 970/X-FiTi
Reply 4 of 26, by Danilo_Dias
gmaverick2k wrote on Yesterday, 16:45:
get VIDECDD.SYS and place into c:\drivers folder Add the following: […]
Add the following:
Config.sys:
Autoexec.bat:
MSCDEX /D:MSCD001
weird, still didnt work,, still loads the VIDECDD.SYS but not the mscdex. if i type the command after start the dos it works but not in autoexec
Reply 5 of 26, by gmaverick2k
Danilo_Dias wrote on Yesterday, 17:35:
Add the following:
Config.sys:
Autoexec.bat:
MSCDEX /D:MSCD001
These are my config files ran as *.pif in win98 under advanced tab, which reboots my pc in real dos mode as per philscomputerlab and a few tweaks:
NOTE: I know mouse driver isnt there, havent got that working yet but no need to atm as i use keyboard for the games i'm playing atm...
config.sys:
[COMMON]
DOS=HIGH,UMB,NOAUTO
FILES=40
BUFFERS=40
LASTDRIVE=H
[menu]
menudefault=EMC,10
[EMC]
[XMC]
[CMC]
[EM]
[XM]
[CM]
[E]
[X]
[C]
Autoexec.bat:
SET BLASTER = A220 I5 D1 T4 P330
LH C:\WINDOWS\AU30DOS.COM
CALL C:\NOLFB\NOLFB.COM
MSCDEX /D:MSCD001
LH C:\DRIVERS\CDBQ\CDBQ.EXE /P2 /Dm /S600
Reply 6 of 26, by EduBat
This line looks incorrect
It should be
LH C:\WINDOWS\COMMAND\MSCDEX.EXE /D:OPTICAL
If, aditionally you want to specify the drive letter you can add /L: at the end
LH C:\WINDOWS\COMMAND\MSCDEX.EXE /D:OPTICAL /L:E
Reply 7 of 26, by Babasha
Danilo_Dias wrote on Yesterday, 16:39:
yes but didnt worked, weirdley when im in dos and manually type […]
Never see such strange things but you can try to make one more .bat file something like cd-drive.bat
and run it from autoexec.bat with
call cd-drive.bat
Need help? Begin with photo and model of your hardware 😉
Reply 8 of 26, by DaveDDS
I never had to "optical" - always worked with simple/basic optiong.
You could also try "SHSUCDX" - also worked well for me.
I see "Sound Blaster" lines in your config ... you're not by chance using an SB drive or the connector on an old SB card?
IIRC: The SB stuff looked like IDE but wasn't
https://dunfield.themindfactory.com ; "Daves Old Computers" ; SW dev addict best known:
ImageDisk: rd/wr ANY floppy PChw can ; Micro-C: compiler for DOS+ManySmallCPU ; DDLINK: simple/small filetransfer(w/o netSW)via Lan/Lpt/Com
Reply 9 of 26, by DaveDDS
Also any messeges when driver or CDX loads?
Reply 10 of 26, by Baron von Riedesel
Ensure your Autoexec.bat contains 0x0D/0x0A as line ends and not just 0x0A.
Reply 11 of 26, by DaveDDS
Is autoexec finding it...
Goto: C:\
Dir/s mscdex.exe
Note the full path
Put that in AITOEXEC line
Reply 12 of 26, by dionb
DaveDDS wrote on Yesterday, 21:01:
The /D variable is completely arbitrary, you can call it BANANA or anything else and it works just as well, so long as you use the same name in CONFIG.SYS and AUTOEXEC.BAT
Reply 13 of 26, by weedeewee
dionb wrote on Today, 00:21:
completely arbitrary as long as you do not use any of the already reserved devicename words.
Do not ask Why !
Reply 14 of 26, by DaveDDS
Ok, makes sense and seems vaguely familiar.
I was thinking you memt "optical" was a special keyword ... it really has been years.
I think I only have two DOS systems left with CD - and I've not had to configure them in a ... L O N G - T I M E ...
Reply 15 of 26, by zapbuzz
it looks like the cdrom is dieing to me maybe try see if it works in windows?
the executive bat is enjoying the attention here!
Anyhow I can say much I don't know enough about the hardware.
Reply 16 of 26, by Danilo_Dias
the cd-rom is beying detected the proble is mscdex.exe is not being loaded in the autoexec
the cdrom drive is working perfectly it works on windows, it workes when i manually put the command to initiate mscdex
Reply 17 of 26, by Danilo_Dias
zapbuzz wrote on Today, 02:30:
hahahaha amazing
Reply 18 of 26, by NeoG_
Is there any output from mscdex saying no device found, or is there no indication that mscdex is running in the first place? Are there any "Bad command or file name" messages that appear during startup?
There is one error in autoexec, "PATH C:\WINDOWS" should be "SET PATH=C:\WINDOWS", unsure if it would cause the problem though
98/DOS Rig: BabyAT AladdinV, K6-2+/550, V3 2000, 128MB PC100, 20GB HDD, 128GB SD2IDE, SB Live!, SB16-SCSI, PicoGUS, WP32 McCake, iNFRA CD, ZIP100
XP Rig: Lian Li PC-10 ATX, Gigabyte X38-DQ6, Core2Duo E6850, ATi HD5870, 2GB DDR2, 2TB HDD, X-Fi XtremeGamer
Reply 19 of 26, by Danilo_Dias
ok i rewrite the autoexec :
SET CTCM=C:\WINDOWS
LH C:\WINDOWS\MSCDEX.EXE\ /D:MSCD001
LH C:\WINDOWS\CTMOUSE.EXE /R2:E
now im finally getting an error message.
weird thing is i even copy the mscdex to windows as well.
