ZuluIDE: A proper IDE device emulator for retro PCs
Reply 280 of 290, by zorprime
Zulu Control Board Question.
1 Does it power on soon as I plug in? Or require a firmware to even power up. Because I build one and nothing shows on screen?
I have a Zuluide 2040 fully working. With no web interface I just eject all day. So much funn. Ps. I have a gotek floppy emu with screen how did they got that working? Did the alien that made the Gotek floppy emu left. Maby they can help with my screen thingi.
Reply 281 of 290, by aperezbios
zorprime wrote on 2026-09-29, 07:44:
Yes, it sure does. No firmware is required. The board simply contains an i2c expander that is probed for by the ZuluIDE firmware. Please see my e-mail to you regarding this, as I'd like to help you get it sorted out.
Reply 282 of 290, by zorprime
ZULUIDE hardware is so well made but there somethings to iron out to be perfet.
1. In Msdos: a utility to load an iso image on auto autoexec.bat would make it a perfect in msdos.
2.in windows98 a easy way to swap iso images with a big screen and a knob will be king
3. And in the future. Loading original and custom firmware xbox360 style would take from windows xp to windows 11.
4. And don't get me started on retro console. That's after if loader custom firmware is even possible.
Reply 283 of 290, by aperezbios
DivByZero wrote on 2026-08-28, 01:52:
To tie off the discussion in this thread, the issue has been logged here, with detailed hardware information and logs:
https://github.com/ZuluIDE/ZuluIDE-firmware/issues/386
I'm happy to continue to work on information gathering and troubleshooting from that ticket.
This issue was resolved in ZuluSCSI firmware release https://github.com/ZuluIDE/ZuluIDE-firmware/r … tag/v2026.10.14
Quoting from https://github.com/ZuluIDE/ZuluIDE-firmware/i … ment-6257217828:
DivByZero wrote:
I'm happy to report that with the 2026.10.14 firmware, the ZuluIDE device worked perfectly in all scenarios I previously had issues in. Looks like this is all fixed! Much appreciated.
Reply 284 of 290, by crusher
zorprime wrote on 2026-10-02, 19:57:
That really would be brilliant.
If it's a command line tool or can work with parameters you can include it in a .bat file and load the needed image before game start.
Reply 285 of 290, by trumpetlicks
Is there anyone that can elucidate how the new v2.5 hybrid board connects to a Pi module the way the older variants do to allow the Wireless control? Also, is there anyone here that has a picture of the control board as they are selling them today. I want to know if I purchase one, what other components I would have to put on it to get it to work (as they state on the website that there are components that would be necessary, but don't provide any pictures or much more information)?
Many Thanks 😀
Reply 286 of 290, by red_avatar
Shortly after I got it, I kind of dropped the ZuluIDE because it couldn't handle many CD images via the web interface (which is my preferred method of swapping images) but I'm working on tweaking the firmware to overcome that problem and also working on a proper web interface that will be hosted on my NAS which should be VERY snazzy. Here's a picture to give you a preview:
It will basically redirect the default web interface to the much improved one running on my NAS with a JSON file keeping track of all the images, adding box art, manuals, etc. The idea is to control it via my small tablet.
Retro game fanatic.
IBM PS1 386SX25 - 4MB
IBM Aptiva 486SX33 - 8MB - 2GB CF - SB16
IBM PC350 P233MMX - 64MB - 32GB SSD - AWE64 - Voodoo2
PIII600 - 320MB - 480GB SSD - SB Live! - GF4 Ti 4200
i5-2500k - 3GB - SB Audigy 2 - HD 4870
Reply 287 of 290, by red_avatar
OK I updated the firmware on the Pico W and now the webpage looks as follows:
Anyone interested in the control firmware let me know. It's based on the latest version (zulucontrol-v2026.07.17).
This is a completely local page - it does not (yet) use external storage but it certainly is a lot neater than the default interface.
Retro game fanatic.
Reply 288 of 290, by zapbuzz
mbalmer wrote on 2025-01-16, 04:22:
One of the things that's always been an issue with emulating retro PCs has been the optical drive. There have been plenty of sof […]
One of the things that's always been an issue with emulating retro PCs has been the optical drive. There have been plenty of software solutions that allow you to mount optical media images once the operating system has booted. We all remember using things like Daemon-Tools, NERO, Alcohol 120%, or Toast to archive and use images of software on our boxes, or, more recently, SHSUCDX on the DOS command line. However, there's always been two areas where you still needed a physical drive to do the job: booting from discs, and playing audio that frequently was coupled with big-box games of the era. Floppy disks had the Gotek -- a device that's pretty much ubiquitous now in the retro community. Pop your disk images on a USB stick and go, boot from it, write back to it, extended formats, weird encodings, whatever. As long as the computer had a Shugart interface, it works.
Which is where the ZuluIDE steps in. The ZuluIDE uses an RP2040 MCU in combination with a Lattice iCE5 FPGA to achieve the timings necessary to communicate over the IDE/ATAPI bus. It started appearing almost a year ago in a public beta form, and while it had some limitations and hangups based on certain configurations, it operated well, and it operated fast. Additionally, with a lot of work and a lot of hardware testing, it's come a long way since its initial release in February of 2024.
To celebrate the upcoming one-year anniversary of the public beta release of the ZuluIDE, we're proud to list some of the accomplishments, fixes, and features that have been added to the project since its inauguration.
Here are some of the major features it had at initial release:
  • Initialize as a CD-ROM device type at boot time
  • Eject and cycle through images using the operating system
  • Emulate other removable media devices like ATAPI Zip drives
  • Present to the system as either a primary or secondary device, configured by DIP switch
  • Boot from an image loaded from SD card, if the BIOS supports booting from an optical device
  • Disk images not limited to standard optical media sizes -- as long as it's in .ISO format, you can mount an image as big as your system will support reading.
  • Operate at bus speeds up through PIO 3/UDMA 0
And, almost a year later, here are some of the milestones that have been added since:
  • USB Mass Storage support (use a ZuluIDE via a USB cable for direct access to the filesystem on the SD card)
  • Physical, Gotek-like hardware interface (optional; currently being finalized -- DIY version can be made available upon request)
  • Web-based control interface using an additional Raspberry Pi Pico W attached over I2C
  • Support for certain non-computer systems that use IDE devices (e.g., Roland SP-808 samplers)
  • Present specific ATAPI and IDE device ID strings to the BIOS if needed
  • Hot-plugging of SD media
  • Hard disk emulation support
  • Automatic calculation of hard disk image geometry details
  • Significantly-expanded workable hardware range includes many 286, 386, and 486-based systems utilizing onboard IDE interfaces or traditional multi-IO cards and even sound card CD-ROM interfaces
  • Greatly-improved compatibility with systems that poll the IDE bus at boot time to determine devices attached and significant improvements in proper device enumeration under DOS, FreeDOS, and Windows
  • Redbook audio playback with .BIN/.CUE file format images for software that used it by attaching a small I2S DAC shield
Work to further improve the ZuluIDE is continuing, specifically in the speed department, specifically towards implementing further UDMA modes and additional quality-of-life features.
The ZuluIDE is available to be purchased at https://www.zuluide.com in the US, and there are resellers for the ZuluIDE in both Germany and the UK.
Does this have support for copy protected CD's? Perhaps an approach to alcoholsoft to load their images (early win98 version)
Reply 289 of 290, by red_avatar
Another update: the firmware of both the Zulu & Pico W have been changed, I've tested with over 500 CD images, added manuals & covers and it works beautifully! The Pico basically sees if it can detect the website that hosts it all (on my NAS), if it can't find it, it defaults to the basic site without images. You can point it towards any site you want so this can run off a Raspberry Pi as host. It's fast, it's easy, it's sexy:
Retro game fanatic.
Reply 290 of 290, by red_avatar
zapbuzz wrote on 2026-11-07, 18:15:
No it doesn't - bin/cue and iso files don't keep any copy protection. You need very different file images for that which are difficult to emulate. PCs that need those copy protections are generally powerful enough to run Alcohol with a few exceptions around 1997-1998. CD audio is the main issue but I think few games with copy protection have CD audio so you could use the ZULU + Alcohol as a combo with ZULU mainly for DOS.
Retro game fanatic.
