First post, by Germin
Hi, everybody!
I have a question related to the MIDI IN of the X-Fi card with the I/O Drive:
I own the X-Fi Platinum but I don't have the I/O Drive (just like having the XtremeMusic). I can see the MIDI OUT in programs like Cakewalk Sonar,... to enroute the MIDI OUT through the X-Fi, but the MIDI IN is not listed...
-Is it just because I don't have the I/O Drive?
  -A test: Can anybody unplug the drive (the ribbon cable attached to the AD_EXT) and restart Windows in order to see if the MIDI IN removes from the list of MIDI Inputs available? This will probe if I NEED the drive, or else it is a matter of drivers. I wonder if the drive 'tells' the card that a MIDI IN device can operate, and so, it should be listed.
Thank you very much in advance! 😀
