Duke Nukem 3D 3DFX Voodoo 3 Patch (2026)
Reply 60 of 64, by NeoG_
Chadti99 wrote on 2026-11-07, 14:27:
So performance is still better in software mode on my AMD 5x86@200mhz running 640x480. This latest build does make a noticeable […]
So performance is still better in software mode on my AMD 5x86@200mhz running 640x480. This latest build does make a noticeable improvement and it’s quite playable but I think there is more performance to be had. Keep up the great work!
Standing on roof top after ship crashes and settles:
Software 640x480: 24fps
3dfx 640x480: 18 fps
Yes that is essentially the conclusion I came to looking at performance numbers, at this stage it only makes sense if you have enough spare CPU cycles to overcome the 3dfx path overhead and are using 800x600.
Since there’s no source code only binaries I am speculating that the majority of the overhead is doing triangle, texture and lighting set up for 2 triangles per column, essentially forming a textured quad that represents what each column would have been rendered to the screen.
It’s much less complex as a conversion than doing surface translation because features like distance lighting basically work out of the box, but results in much more triangles that need to be computed before sending to the graphics card.
98/DOS Rig: BabyAT AladdinV, K6-2+/550, V3 2000, 128MB PC100, 20GB HDD, 128GB SD2IDE, SB Live!, SB16-SCSI, PicoGUS, WP32 McCake, iNFRA CD, ZIP100
XP Rig: Lian Li PC-10 ATX, Gigabyte X38-DQ6, Core2Duo E6850, ATi HD5870, 2GB DDR2, 2TB HDD, X-Fi XtremeGamer
Reply 61 of 64, by Duffman
@TgamesFR
what was the reason you chose binary patching and not writing a 3dfx patch with the duke3d source code?
MB: ASRock B550 Steel Legend
CPU: Ryzen 9 5950X
RAM: Corsair 64GB Kit (4x16GB) DDR4 Veng LPX C18 4000MHz
SSDs: 2x Crucial MX500 1TB SATA + 1x Samsung 980 (non-pro) 1TB NVMe SSD
OSs: Win 11 Pro (NVMe) + WinXP Pro SP3 (SATA)
GPU: RTX2070 (11) GT730 (XP)
Reply 63 of 64, by willow
TgamesFR wrote on 2026-11-06, 21:46:
Thanks for the feedbacks. […]
Next patchs coming are :
- Archimedean Dynasty
- Blood
- Hi-Octane (Creative 3D Blaster to Voodoo 3 patch)
- Rebel Moon (Creative 3D Blaster to Voodoo 3 patch)
- MechWarrior 2
- StarFighter 3000
- System Shock
- Terminal Velocity
Then i will do a small break on releases until we have enough testing for existing ones.
For Statically linked (Voodoo 1/2 only) all interesting titles are now supported on the Voodoo 3 (the last ones will be StarFighter 3000 & MechWarrior 2 who are ready for next week).
Only 2 games will not be worked on because they are soccer games (Actua Soccer ‘96 (also know as VR Soccer '96) and UEFA Champions League 96/97), so i don't think it worth working on them.
So except if there is really a high demand they will not be supported.
Is it possible to add flight unlimited support ?
Flight unlimited had power vr and 3d blaster cgl support but not 3dfx
Reply 64 of 64, by TgamesFR
I've changed my mind i will support 2 more games :
- Actua Soccer
- Shadow Warrior
Normally with thoses we will have a 99% compatibility now.
willow wrote on 2026-11-08, 12:58:
I will look on it but it's not a priority.
