First post, by Danger Manfred
Hi!
I have two wavetable daughterboards, both by Terratec. One is the Wavesystem Professional SOWT-24 and it works just fine.
The other is the Dream GSWave from the title. And in some situations it reproducably starts shittyfluting my MIDI music!
For instance the second half of Duke Nukem 3D - Grabbag, or Sonic 3 - Ice Cap Zone as soon as the key melody sets in. The beat sounds a bit off, too. It's hard to describe.
I tried both daughterboards with different "carrier" sound cards and in several different PCs with completely different motherboards, the result is always the same.
Does anyone have an idea what might cause this?
Reply 1 of 10, by auron
possibly a weak onboard CPU that can't keep up with fast MIDI messages. the 80C32 on that board is a fully 8-bit design, while the roland and yamaha modules from the time used 16-bit internal/8-bit external designs. the 80C32 is clocked higher at 33 mhz though...
besides, the board with the issue has a much earlier dream chipset anyway. try to find out whether there is another board with that chipset but a different microcontroller.
Reply 2 of 10, by Danger Manfred
auron wrote on 2026-02-05, 14:43:
Mh, if that's by design, it would be real bad.
I'll try to find someone who has the same daughterboard and find out if theirs sounds as bad as mine then.
I noticed that unlike the SOWT-24, it has not 32 but 24 voice polyphony, but I doubt any of the MIDIs were using more than 24 voices simultaneously.
Reply 3 of 10, by Danger Manfred
I tried recording this with Audacity 1.3 Beta on W98SE, but whatever I record is real choppy (also the audio graph updates really choppy). At first I thought it was because the system was relatively slow (166 MHz, 64 MB RAM), but even after upgrading it to a K6-2+ 550 and 256 MB SDR-100 it still has trouble recording smoothly. Will have to fix that first (or rather find a less demanding recording tool) so I can show the actual issue.
Reply 4 of 10, by auron
that audacity is from 2011, probably not written for a K6 that doesn't even have SSE. you can't record it on a newer computer?
i have found the SCW001/2 on wavetable.nl, has the SAM9203 and 80C32 like yours, but uses different a crystal ROM and lacks the SAM8905B effects processor. doesn't seem to be doing too bad in the recordings, but you can tell at the end of grabbag it's slightly off beat. it's subtle though.
anecdotally, i have heard that the 10mhz 68k that was on a lot of MIDI hardware is also not the best for heavy MIDI files, like what you would get in doom or duke3d user content. it's hard to say for sure if timing issues are coming from the tone generator or the onboard MCU, but i think one good benchmark is to use MIDI thru, on a slow MCU it should wreck performance. only applies to external modules and not daughterboards obviously.
Reply 5 of 10, by Tiido
The "user content" can be made in a way that would only be playable on a softsynth by having so many MIDI messages that would saturate the 3125 bytes/second bandwidth of a MIDI UART link. I have plenty of MIDI files that I cannot play over a single piece of hardware over MIDI just because of this issue. They choke and hiccup and stutter and at the same time make the machine very unresponsive as the MIDI driver is waiting for bytes to send because FIFO is full too...
Reply 6 of 10, by auron
yeah, i'm aware of files like that, but the difference is they choke on any MIDI hardware because as you say the bottleneck is the MIDI link itself. the issue here, at least if i'm understanding OP correctly, are much more subtle timing issues that just happen on certain MIDI hardware.
3125 bytes/s should be a small number to read even for a MCU design from 1980, but at the very least it's twice than that from having send the MIDI stream to the tone generator, and the MCU in these devices is performing other tasks at the same time. the H8 in the SC-55 etc. is much newer and probably more capable, which is why you don't see these issues as much in those devices. alternative explanations could be wave memory read bandwidth limitations on the tone generator or even too slow attack on certain patches...
Reply 7 of 10, by moturimi1
I found a weird behaviour of my Dream GSWave:
- the Wavetable works on a Sound Blaster CT2940 but it does not work on A Sound Blaster CT2230 or other Sound Cards with Wavetable Header
- intestestingly I tested the close relative a Terratec SOWT-24 (WaveSystem Professional) on both CT2940 and CT2230 and it is working.
- the power supply has -5V and -12V support.
I tested the GSWave also on more than one SB16 CT2230 card that I own and always the same result: The GSWave stays silent on all except the CT2940.
Does someone have an idea why?
Could something be broken on the Wavetable Board?
Reply 8 of 10, by ripsaw8080
Rank DOSBox Author
DOSBox Author
Perhaps the daughterboard in question needs +12v/-12v from the wavetable header, as some others do, but I've read that not all models of SB actually provide power to those pins.
Reply 9 of 10, by moturimi1
I checked the CT2940 and the CT2230.
Both provide +5V, +12V and -12V to the Wavetable Header.
I checked it with a multimeter.
Some other idea?
Reply 10 of 10, by gerwin
moturimi1 wrote on 17 minutes ago:
I checked the CT2940 and the CT2230. Both provide +5V, +12V and -12V to the Wavetable Header. I checked it with a multimeter. S […]
Some other idea?
Soundcard not sending the reset pulse at startup in a way that the Daughterboard finds acceptable?
Dream SAM 9203 based boards are sensitive to simultaneous program change messages, and may skip some of them when it cannot keep up. SAM 9233 is improved in that regard.
