First post, by NeoG_
For the longest time I couldn't figure out why the orignal game would work fine but Special Edition wouldn't run the installer or the game on my K6-2+ 98SE/DOS machine. After a bunch of experiementation, I narrowed it down to the game not working if I=B000-B7FF is is set as an included memory range for EMM386.
I'm curious if this is a quirk in my system or if this is more generalised, has this happened to anyone else?
98/DOS Rig: BabyAT AladdinV, K6-2+/550, V3 2000, 128MB PC100, 20GB HDD, 128GB SD2IDE, SB Live!, SB16-SCSI, PicoGUS, WP32 McCake, iNFRA CD, ZIP100
XP Rig: Lian Li PC-10 ATX, Gigabyte X38-DQ6, Core2Duo E6850, ATi HD5870, 2GB DDR2, 2TB HDD, X-Fi XtremeGamer
Reply 1 of 3, by Harry Potter
Well...a long time ago, I was thinking about writing some games for DOS, and my PCGPE docs indicated that the VGA card had a feature that lets the system use 128k VRAM at a time. Maybe the game uses that feature. Does the game work on other systems that use that config?
Joseph Rose, a.k.a. Harry Potter
Working magic in the computer community
Reply 2 of 3, by DoZator
NeoG_ wrote on 2026-11-05, 22:58:
Yes, this sometimes happens on some computers. Usually, installing B100 (B200/B300/B400) instead of B000 helps.
Reply 3 of 3, by dr_st
DoZator wrote on Today, 06:13:
Yep. I've been using B400 on my K6-2+ system and it has far fewer compatibility problems. Most likely B100/B200 would also be OK, but I already have enough UMBs as it is.
