First post, by H3nrik V!
So, what do y'all think about this one. Bought on an auction site with little description. Couldnt see the etched speed marking in the corner - well because it wasn't there.
It has a cut Pin A4, which is consistent with an early POPD5V, but Gemini suggests it's a 63 though.
It has one more decoupling cap than my known PODP5V83 but no laser etching on the heat sink.
Heat sink looks sligthly smoother than the known 83, but ALL over, even on the raised part, so doesn't look like it's been altered.
Here a picture next to my 83. Gimme your thoughts, please.
If it's dual it's kind of cool ... ๐Ÿ˜Ž
Please use the "quote" option if asking questions to what I write - it will really up the chances of me noticing ๐Ÿ˜€
Reply 1 of 16, by H3nrik V!
Got the chance today to shoot some photos under a microscope.
Put a little IPA on the corner, where the speed is usually laser etched to experiment with how light refracts. I even rubbed it a bit with my finger nail. Wouldn't put anything on the heat sink due to the hand written text.
Any thoughts whether this is legit? I can't see any signs of alterations in terms of machining marks or anything.
Reply 2 of 16, by H3nrik V!
More pics
Reply 3 of 16, by pyrogx
Maybe ES == "Engineering Sample" ???
Reply 4 of 16, by H3nrik V!
pyrogx wrote on 2026-11-13, 13:31:
Allegedly yes, but I can't find ANY other PODP5V83 or PODP5V63 for that sake online as engineering samples, so I have no idea if this is a legit Engineering Sample or some remarked part.
Waiting to find a disk or CF card of max 8 GiB for my 486 build to install NT4 so I can get some stepping data etc. from the CPU.
Reply 6 of 16, by nickles rust
How fast will it run?
Reply 7 of 16, by H3nrik V!
nickles rust wrote on 2026-11-13, 15:29:
Haven't gotten an OS up and running yet, I'm challenged on IDE storage in the sub-8GB range ... does run the NT4 installer at 83, though, but due to the 16gig CF card, system won't boot. Double checked with my known 83MHz to verify it wasn't a CPU issue
Reply 8 of 16, by wierd_w
While... not ideal... ez-drive *can* work with NT4 SP6.
The boot partition must be under 8gb. The overlay just allows ntldr to access the disk. It uses ATAPI.SYS after initial load with ntldr.
http://site.iendraguignan.free.fr/telecharger โ€ฆ rive_FAQ.htm#os
NT4's boot-installer can use the universal ata driver as well. It's a bit of a pain to integrate with the install cdrom, but is doable.
http://alter.org.ua/soft/win/uni_ata/uni_ata.php#inst_nt4
Together, you should be able to have a data volume larger than 8gb, on a disk that is large.
Reply 9 of 16, by H3nrik V!
wierd_w wrote on 2026-11-13, 16:40:
While... not ideal... ez-drive *can* work with NT4 SP6. [โ€ฆ]
What I understand here is that ez-drive should be sufficient to install and boot on a 2 gigabyte partition?
Reply 10 of 16, by wierd_w
Yes.
You install ez-drive with the 'automatic' mode, and tell it you want to install NT4.
It will install the DDO, and create a partition for you, tell you to insert the NT4 cd, reboot, then hold down C button I believe) to do eltorito boot AFTER loading the ddo.
You then install NT4, like you normally would.
At least, that's what my increasingly forgetful brain says.
Reply 11 of 16, by H3nrik V!
wierd_w wrote on 2026-11-13, 20:31:
Yes. [โ€ฆ]
Yes.
But to install ez-drive, I suspect I would need to have an OS installed first? The thing is, I'm not sure it will even boot DOS 6.22 from that cf card ๐Ÿค” gotta re check tomorrow.
Reply 12 of 16, by wierd_w
The install disk for ezdrive is itself bootable.
Reply 13 of 16, by H3nrik V!
wierd_w wrote on 2026-11-13, 22:02:
Thanks, gonna try it.
Reply 14 of 16, by H3nrik V!
So far so good, DOS 6.22 runs on a 2gb partition made on the 16gb card with EZ Drive. NT4 BSOD'ed after install. Copying the i386 folder from win 2000 sp4 now to try that
Reply 15 of 16, by MikeSG
The heatsink fins are thicker on it as well suggesting an early version.
If the CPU is a known production stepping, maybe only the heatsink is an ES.
Reply 16 of 16, by H3nrik V!
MikeSG wrote on Yesterday, 08:44:
Good spot. Wonder if they're really thicker or image is tricky.
It's a 01532 stepping, so same as normal 83s
