Reply 260 of 264, by vico
- Member
mwdmeyer wrote on Yesterday, 12:23:Can you tell me: […]
Can you tell me:
Which Windows it is (95 retail, 95 OSR2 or 98).
The desktop resolution and colour depth at the time, and whether this was the first boot after installing the driver.
Whether 640x480 at 256 colours shows it too, and whether any colour depth draws correctly.
A photo of the screen.
The files V9XBOOT.INI, V9XHW.INI and V9XDD.INI from C:\V9XDIAG, copied after the bad boot (Safe Mode is fine for copying them).In Device Manager, please also check that the driver is on the first Radeon entry and not on the card’s secondary device.
So far, I’ve only tested it on Windows 98SE; it happens right when you click the "Settings" tab in "Display Properties," but when the screen becomes distorted, the 16 thumbnails aren’t always visible.
